Author Topic: 400/4 spark plug helicoil  (Read 6272 times)
Offline Harold 400/4
« on: August 10, 2015, 08:59:03 PM »
Looking to sort the plug threads on my 400/4. From past posts, helicoils look to be the way to go.
I have read the inserts can come out when you take the plugs out?? Has anyone had any issues with helicoils?
Many thanks
Harold.
Offline tom400f
Re: 400/4 spark plug helicoil
« Reply #1 on: August 10, 2015, 09:06:13 PM »
Had one done on my CB175K6 back in the day. It was perfectly fine afterwards - good as new
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline Green1
« Reply #2 on: August 10, 2015, 09:10:27 PM »
My Guzzi is full of them not been an issue yet.  :)
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #3 on: August 10, 2015, 09:12:32 PM »
A Wurth insert or sometimes called a timesert is better, it's like a metal tube that's threaded inside and out. Offers better heat dissipation as well.
« Reply #4 on: August 10, 2015, 09:13:57 PM »
Mick
Till the next time you try and remove a bolt/stud if you re used the shitalian bolts
Offline Green1
« Reply #5 on: August 10, 2015, 09:16:07 PM »
You just unwind the insert then  ;)
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline Greg65
« Reply #6 on: August 10, 2015, 10:44:33 PM »
If it's just the beginning of the thread then you might like to consider a back tap. I recently used one and while the tool is not perfect at £30 it will do, there is an ideal one state side at over £100. I got mine from motorcycleproducts.co.uk.
Greg
Keep smiling it makes the management nervous.
Honda CB400 1976
Suzuki GS1000 1978
