Author Topic: 52141-369-000 Swing arm rear centre collar  (Read 7911 times)
Re: 52141-369-000 Swing arm rear centre collar
« Reply #15 on: September 25, 2015, 09:33:40 PM »
The top hat type bushes don't normally have the steel end caps and the frame is supposed to trap the collar when the bolt is tightened so that bushes move on a fixed pin.
The original bushes are set into the swingarm and have a felt washer to seal the collar, a plastic thrust and then the end cap
