Author Topic: Brakes adjustments  (Read 7884 times)
Offline El__burro
Brakes adjustments
« on: September 22, 2015, 03:42:30 PM »
Good day, i have almost finished my project (just left to change the rear tyre and complete registration of my cb750 k2).
After having filled up my front brake system with oil i have a problem.
The front wheel is pretty hard to turn as the brakes pads are holding on the disks.
I have a dual front brake.
The disks seem pretty straight.
Any ideas for sorting this out.
Thanks a lot
El__burro
« Last Edit: September 22, 2015, 03:44:07 PM by El__burro »
Re: Brakes adjustments
« Reply #1 on: September 22, 2015, 04:08:14 PM »
when I fitted dual discs I had that issue on the OS/new side,
the caliper alignment is crucial,as it needs to press the pads directly onto the disc,
I was lucky,I could ride the bike,then check the rubbing part of the pad,and make adjustments with a file,
try removing the pads,then see how well the caliper meets up with the disc,
you might find either the top,or bottom touch first,
does the lever feel soft/spongy ??
make sure the moving pad slides in the caliper easily,
Offline El__burro
« Reply #2 on: September 22, 2015, 05:47:50 PM »
it looks like the moving pad on one side ( the other is fine) that doesn't retract.
I guess i need to remove the calliper and inspect it to work out why is not sliding in.
the lever feels soft, no friction or pressure.
thanks
el__burro
Offline NigelWilmshurst
« Reply #3 on: September 23, 2015, 08:15:45 PM »
I had the same problem on my twin disc conversion, after lots of headache I realised the piston seals I had ordered from David silver were too big and not allowing the pistons to return freely, which also created drag on full lock, ordered the correct seals through my local honda dealer and filed the pads.
Eventually sorted the problem out, the lever feels slightly spongy but actually works fine, the F2 reservoir may of been a better choice as it's bigger.
Nigel
Cb750 f1 1976
Cb750 f2 1978
Cb750 hondamatic 1978
Cbx1000 1980
Kz1300 1981
Cb750 k3
Fzr1000genesis
Other bikes in bits
Offline El__burro
« Reply #4 on: September 23, 2015, 11:02:32 PM »
i thought of removing the calliper to have a look but then i realised that the disk is probably not straight as when i spin the wheel it goes free one a side and stuck for another bit.
if that is my problem, how easy is to fix.
El__burro
« Reply #5 on: September 23, 2015, 11:22:41 PM »
check the disc mounting
   "             " for warping,(the same way you would true a wheel rim,
 if its distorted,I guess its scrap,
Offline El__burro
« Reply #6 on: September 24, 2015, 07:57:48 PM »
In the pictures below it's visible the variance on the disc.
Not sure if this means that the disc is not good or there is a tolerance "allowed"
El__burro
« Reply #7 on: September 25, 2015, 08:08:48 AM »
Is the disc carrier fitted squarely on the hub?
Offline El__burro
« Reply #8 on: September 25, 2015, 08:35:20 AM »
I guess the only way to tell is by removing the disc and put it on a flat surface. I'll check for the bolts tightness first. Do you know what's the torque setting?
Any other suggestions?
El__burro
« Reply #9 on: September 25, 2015, 09:05:34 AM »
before trying to tighten I would make sure there is nothing contaminating the mating surfaces, You haven't tried to use a standard speedo drive plate have you?
Offline El__burro
« Reply #10 on: September 25, 2015, 02:39:03 PM »
After tightening all the bolts to 40 nM the disc seems straight.
The wheel spins free but when I pull the brake it goes a bit tough until I punch the calliper towards the wheel.
I guess the punch helps the pad to retract once it hits the disc.
El__burro
« Reply #11 on: September 25, 2015, 03:33:19 PM »
it seems the pad is meeting the disc squarely,
 roughen the pad surface,re-fit and spin the wheel,then un assemble,see were the disc is rubbing the pad,use a file to take away the
high spot,continue until the wheel spins,and make sure the piston retracts,and the pad moves easily on the caliper.
the fixed pad is almost self aligning,
Offline El__burro
« Reply #12 on: October 14, 2015, 03:59:17 PM »
After removing the calliper and unsticking the brake pads (it had some extra bit on one side) the disk turns freely;
the new issue is that i need to pull the brake lever a few times before it locks the brake.
what shall I do next?
thanks
El__burro
« Reply #13 on: October 14, 2015, 04:36:01 PM »
Try adjusting it. Undo the locknut and adjust until there is just about 6thou between the fixed pad and the disc.
Sent from my D2303 using Tapatalk
