Author Topic: CB350F a couple of easy questions  (Read 10576 times)
Re: CB350F a couple of easy questions
« Reply #15 on: September 23, 2015, 06:05:54 PM »
Plastic doofer =17271611010  breather chamber.  Its supposedly a device, not fitted to 350fours, to decrease harmful emissions.  They obviously don't work otherwise VW would be using them.
Offline Bullit
« Reply #16 on: September 23, 2015, 06:19:33 PM »
That's it Roy. Could have sworn mine joined together at some point though.
Like the VW pun there Mike 👍
« Reply #17 on: October 01, 2015, 06:20:13 PM »
Job done. Just fitted the new breather pipe on the bottom of the plenum chamber. Turns out it has a little air filter element fitted at the top so it doesn't matter if it sucks air in via the breather/drain. Clever stuff, that's another for the knackered old memory to retain.
Offline Gixxer-18
« Reply #18 on: October 04, 2015, 11:23:29 PM »
If it helps this is my breather tube, the outer sleeve is hard and brittle but this was how it was fitted to my bike, I haven't removed it yet as it will be destroyed when I split the crankcases tomorrow.
HTH
NIGEL.
« Reply #19 on: October 05, 2015, 07:24:19 AM »
Cheers for that and welcome to the forum. I assume from the name you also have a Suzuki. That's exactly how mine has gone back.
