Author Topic: Feeler strips  (Read 11186 times)
Offline peterengland
Feeler strips
« on: September 22, 2015, 08:36:06 PM »
I am looking for feeler strips for the 550 tappet clearances of 0.08mm and 0.05mm had no luck on the net so far, anyone got a supplier please?
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Re: Feeler strips
« Reply #1 on: September 22, 2015, 08:59:04 PM »
Re: Feeler strips
« Reply #2 on: September 22, 2015, 09:06:58 PM »
I my day, all feeler gauge sets came with a 2 and a 3 thou.
I blame this metric foreigners.
Re: Feeler strips
« Reply #3 on: September 22, 2015, 09:09:06 PM »
Cheers for this guys, may have to go with Louis ones but they are standard length and real fiddly to use so was ideally looking for long individual strips that I can bend at the ends if such things exist.
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Re: Feeler strips
« Reply #4 on: September 22, 2015, 09:17:37 PM »
In workshops they used to have rolls.
Offline matthewmosse
Re: Feeler strips
« Reply #5 on: September 22, 2015, 09:43:59 PM »
I bought a set of cheap draper ones that are meant to fold into their case, but have simply bent the relevant ones to suit and leave them stuck out a bit ( appart from my dad helpfully streightened them and told me I need to store them more carefully as they had got bent in the drawer, doh! ) you can just unscrew the top bolt to loose the things off if you want individual gauges seperated.
Re: Feeler strips
« Reply #6 on: September 23, 2015, 04:19:49 PM »
Mr Moose you are probably right there, having the whole lot of 'em in your hand trying to get the 1 inch strip down into the tappet clearance is a nightmare! I used to work in a garage back in the 70's and we had 1ft long individual strips, sooooo much easier!
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Re: Feeler strips
« Reply #7 on: September 23, 2015, 05:46:42 PM »
Would that be for Vauxhaul vivas by any chance? you had to adjust those with the engine runnining which foobarred the feelers
Re: Feeler strips
« Reply #8 on: September 23, 2015, 06:35:03 PM »
MatthewMosse has the right idea.  If you don't separate them, the weight pulls them out of the gap you're trying to measure.
Tip of the day.
Get a decking screw from B&Q with a 3mm square drive.  Cut the threaded part off,  you only need the head.  Fix the head to a screwdriver or something.   You now have an ideal tool for adjusting tappets.
Re: Feeler strips
« Reply #9 on: September 23, 2015, 07:45:44 PM »
Yeah Opels and vauxhalls, all adjusted with engine running, so easy man!
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Offline MCTID
Re: Feeler strips
« Reply #10 on: September 23, 2015, 08:23:23 PM »
I used to use feeler 'strips' to measure the clearances around Turbo Compressor Impellers. The strips came on a coil and I cut off about a metre at a time to feed around the Impeller/ Casing to check what the clearances were.
Another 'unusual' technique I remember at the time was micro peening areas of a shaft journal to bring up the outside diameter so that the sensors read zero run out when turned by hand. If the sensors detected excessive run out as the Gas Generator (Rolls Royce Avon Jet Engine) got up to speed, the whole Turbo Compressor shut down and it took ages to set it all up again, often needing to replace the main journal bearings.
We also had to allow for the Turbine Shaft to lift as it expanded so that it came into line with the Gas Generator Shaft and ran perfectly true within milliseconds.
You can't beat 'kidology'.
Offline MeilakJ
  • Life is what you make it!!
Re: Feeler strips
« Reply #12 on: September 23, 2015, 08:43:04 PM »
They look rather nifty
Offline dellenty1234
Re: Feeler strips
« Reply #13 on: September 25, 2015, 06:13:13 PM »
got mine from Halfords!
Take it apart anyway he says.....
Offline gtmdriver
Re: Feeler strips
« Reply #14 on: September 28, 2015, 10:16:30 AM »
I got these from RS Components.
There are five 0.002" feeler gauge strips about one foot long.
They cost £10.49 with free carriage.
You can get them in most thicknesses and at this price you can experiment by cutting or bending a few till you get the perfect shape.
