Author Topic: Swingarm bushings  (Read 8420 times)
Offline Noelia
Swingarm bushings
« on: September 22, 2015, 09:45:15 PM »
Hi all,
I need to replace the swing arm bushings in my cb500 four
Since I'm changing them I would like to put something is going to last.
Any recommendations? I read the original ones are very bad quality? Are the bronze better?
Thanks!!
Re: Swingarm bushings
« Reply #1 on: September 23, 2015, 09:54:28 AM »
Its not bushes that are poor quality its owners that do not grease them often enough!!
Offline Noelia
« Reply #2 on: September 23, 2015, 10:54:31 AM »
I see!! I may be one of those shall I buy the bronze ones? I've read they are easier to install also
http://www.motorcycleclassics.com/mc-how/rear-swingarm-bushings-1973-honda-cb500.aspx
« Reply #3 on: September 23, 2015, 05:45:21 PM »
Installation is no problem, is getting the old ones out that is!! Also you will find that no matter which you fit a new pivot pin will be needed as the pin wears more than the bushes---sit down when you look up the price tho'
« Reply #4 on: September 23, 2015, 06:17:21 PM »
Bryan - do you pre-soak Phosphor Bronze bushes in just general engine oil (10w/40) prior to installation?
« Reply #5 on: September 23, 2015, 07:12:13 PM »
Is the pin hardened Bryan, as I got mine reground to suit slighly smaller ID bushes. The guy in Poland will machine undersize bushes, well he does for the 250/350K.
James ... I think you only oil  soak sintered material not solid phosphor bronze... unless the ones you buy are sintered of course.
Offline Noelia
« Reply #6 on: September 23, 2015, 07:43:32 PM »
Hi bryanj
How does the pivot pin looks like?
Thanks!
« Reply #7 on: September 23, 2015, 07:54:30 PM »
Its item 8 ... Bryan's probably working his nuts off on nights!
« Last Edit: September 23, 2015, 07:56:24 PM by AshimotoK0 »
« Reply #8 on: September 24, 2015, 06:19:58 AM »
Thats the one
« Reply #9 on: September 24, 2015, 03:44:44 PM »
Offline Noelia
« Reply #10 on: September 27, 2015, 05:41:08 PM »
What I really needed is number 4! All sorted now :)
Thank you!
