Author Topic: Chain problem  (Read 23494 times)
Re: Chain problem
« Reply #30 on: October 09, 2015, 08:19:23 PM »
Very! Remove the two short bolts from the locking plate, turn it slightly and it will align with the splines and can be pulled off, then the sprocket just lifts off. Put the new sprocket on, and fit the locking plate, rotate it until the bolt holes line up, then replace the bolts. And yes, it is meant to wobble about when fitted!
Sent from my D2303 using Tapatalk
Offline El__burro
Re: Chain problem
« Reply #31 on: October 09, 2015, 08:48:35 PM »
thanks, but i meant the step just before that.
what covers I need to remove first?
Re: Chain problem
« Reply #32 on: October 09, 2015, 08:51:48 PM »
Just the small rearmost cover over the sprocket, held on with 2 screws. You do not need to remove the gearlever  or the cover under it
Offline El__burro
Re: Chain problem
« Reply #33 on: October 09, 2015, 08:53:17 PM »
Thanks, I'll try tomorrow.
Re: Chain problem
« Reply #34 on: October 10, 2015, 09:57:12 AM »
Chain and sprockets arrived, a week late but they eventually did.
I put on the rear sprocket and new chain but kept the old front sprocket as I am not sure how to replace it.
After having completed the job I have realised that the chain is very loose, i pushed the wheel to the very end but still way too lose.
Shall I cut some links off the chain or..
thanks
el__burro
Same here. Just had a chain and sprocket kit off eBay from M&P for the CB750F2
http://www.ebay.co.uk/itm/HONDA-CB750-F2-1977-SOHC-O-RING-CHAIN-AND-SPROCKET-KIT-/271025338194?
Fitted it last weekend and like yours the adjustment is past half way. So tomorrows job is to remove the required links and put in a soft rivet link. Don't like split links on 630 chain, although I don't know of any problems so I'm probably being way over cautious. Was always told from my teenage years that 65hp was the limit for split links (this may have been true of 70/80s chains). Its probably bullshit but what price your crankcases if it breaks.
Not even going to bother with the ringing M&P as they will only say "we've sold thousands and this is the first report of a problem". That will just piss me off. So out with the link remover again.
« Last Edit: October 10, 2015, 10:00:05 AM by royhall »
Re: Chain problem
« Reply #35 on: October 10, 2015, 11:19:25 AM »
If you've got a link splitting tool, why bother with the soft link? Couldn't you just join the two ends together,  deleting the split link.
Offline MarkCR750
Re: Chain problem
« Reply #36 on: October 10, 2015, 11:32:07 AM »
thanks
el__burro
Surprised at M&P's response Roy, I only ever had good service from them, but it just goes to show that all suppliers can be a problem once they've got the cash!, regarding split links yes you are being over cautious, but why not when its so easy to use the soft link, if anybody does want to use a split link though they shouldn't worry, I've seen them used on 500bhp drag bikes without an issue, there should be no side loading on a chain so the split link doesn't take any stress, I use a split link on my XJR1300.....famous last words? :)
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Re: Chain problem
« Reply #37 on: October 10, 2015, 11:33:29 AM »
That's the plan Mike. The rivet over link that I bought is called a Soft Link, as the ends of the link that get riveted over are soft so they can be worked easily. Probably me not making myself clear again. ::)
« Last Edit: October 10, 2015, 11:42:15 AM by royhall »
Re: Chain problem
« Reply #38 on: October 10, 2015, 11:38:54 AM »
Just want to be clear on this Mark.
I didn't ring M&P as El-Burro had tried and got that response.
I to have never had a problem with M&P and I don't really consider this a problem as I can just shorten it so not worth the trouble ringing. If it had been too short I would have been on the phone in a second.
Just mentioned it as it was the same as El-Burro's problem.
I have a split link fitted at the moment, but the spring keeper on it is not tight and moves around slightly. That makes me nervous about it.
« Last Edit: October 10, 2015, 11:40:56 AM by royhall »
Re: Chain problem
« Reply #39 on: October 10, 2015, 11:56:03 AM »
I know what a soft link is, I use them when replacing cam chains.  I was wondering - why bother.  if you're going to remove links anyway, why not just join the chain together?
Re: Chain problem
« Reply #40 on: October 10, 2015, 12:02:48 PM »
Not sure I understand Mike sorry. Join the ends together with what, isn't that what the soft link does?
Re: Chain problem
« Reply #41 on: October 10, 2015, 02:10:22 PM »
Make it into an endless chain using the link removal tool is what I meant.
Offline El__burro
Re: Chain problem
« Reply #42 on: October 10, 2015, 04:01:33 PM »
Eventually the people at Busters kindly offered to shorten the chain and send it back too for free, all I had to pay £5.50 for sending the chain to them.
I just think that they should mention on their page to choose EU or US models.
Considering how easy is to shorten, it's not worth leaving a bad feedback (the delivery was a week late too).
Price/quality ok.
By the way, chain and both sprocket are on.
Just need a test ride.
El__burro
Offline MarkCR750
Re: Chain problem
« Reply #43 on: October 10, 2015, 07:51:36 PM »
Looks a bit tight in the photo?
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
Re: Chain problem
« Reply #44 on: October 11, 2015, 01:10:04 PM »
Maybe it will need 1 link putting back  ;D ;D ;D
