Author Topic: Chain problem  (Read 23987 times)
Re: Chain problem
« Reply #45 on: October 11, 2015, 03:38:56 PM »
1 pair.   You can't have 1 extra link.
Offline El__burro
Re: Chain problem
« Reply #46 on: October 11, 2015, 05:21:55 PM »
not sure if I should laugh along.
when i removed it from the stand got a bit better.
what should it look like?
thanks
El__burro
Re: Chain problem
« Reply #47 on: October 11, 2015, 06:26:58 PM »
There should be about 20mm free play when on the wheels (not on the stand )
Re: Chain problem
« Reply #48 on: October 11, 2015, 07:13:44 PM »
Are you sure  ;D ;D ;D
Re: Chain problem
« Reply #49 on: October 11, 2015, 08:41:32 PM »
You know I'm right Trig.  Stop trying to confuse El Burro.
Offline El__burro
Re: Chain problem
« Reply #50 on: October 11, 2015, 08:53:05 PM »
thanks, i've read it before about the 20mm play.
unfortunately, the bike seems to have a problem, the engine struggles to go even at idle.
i've looked into the tank and it is full of bits (looks like rust) could it be carburettor?
thanks
el__burro
Re: Chain problem
« Reply #51 on: October 11, 2015, 08:58:49 PM »
I had a 400four tank that had rusted inside the tank.  There was hardly any fuel coming out of the tap because the filter was blocked.   Worth checking.
Re: Chain problem
« Reply #52 on: October 11, 2015, 09:00:03 PM »
Could be, but before you go ripping the carbs apart, it may be the internal filter in the fuel tap. You need to drain the tank and flush it out first, then when it is clean, check the fuel tap filter. If running doesn't improve after that, then it's time to strip and clean out the carbs
Re: Chain problem
« Reply #53 on: October 11, 2015, 09:59:34 PM »
That's the filter I was referring to.   When I pulled the fuel hose off the tap, not much fuel came out.
Offline El__burro
Re: Chain problem
« Reply #54 on: October 13, 2015, 08:29:58 PM »
Removed the fuel tap (and destroyed it) emptied the tank, fuel is very dirty with a lots of these dark balls (of rust i guess).
I have flushed the tank a few times but now I need to replace the part in the tap.
Any idea where to shop for it?
Regards
El__Burro
Re: Chain problem
« Reply #55 on: October 14, 2015, 07:05:23 AM »
Offline El__burro
Re: Chain problem
« Reply #56 on: October 14, 2015, 08:20:26 AM »
Last time I bought something from the US i had a nasty surprise with custom charges. DSS sells it for about £10 (hopefully will be in stock soon). Until then I will be on the lookout.
Good day
El__burro
Offline Chris400F
Re: Chain problem
« Reply #57 on: October 14, 2015, 08:58:14 AM »
Custom charges should only apply if the value of the goods is above a certain figure (currently £15).
Offline El__burro
Re: Chain problem
« Reply #58 on: October 14, 2015, 02:51:43 PM »
That's something worth knowing.
After reading this i have gone and bought one.
El__burro
Offline El__burro
Re: Chain problem
« Reply #59 on: October 14, 2015, 02:55:29 PM »
SH*T
I've just realised that I have bought a gasket for the bowl not the bowl i need.
