Author Topic: Fuel petcock repairable?  (Read 13619 times)
Re: Fuel petcock repairable?
« Reply #15 on: September 30, 2015, 12:10:11 PM »
Will make you one soon ....if you still need one
Offline Noelia
« Reply #16 on: September 30, 2015, 03:33:22 PM »
Hi Ash! Yes please Im waiting for you :)
« Reply #17 on: October 01, 2015, 11:05:24 AM »
Just found a bashed up CB750K7 tank languishing behind my shed  :-[ . Took the pertol  tap off it and it has a plastic reserve tube (original fitment)  that should fit perfectly. It tapers at the end where it goes into the alloy and should fit fine. Its from a 1977 tank.
Overall length 92mm, overall OD is about 5.8 but it tapers the last 15mm down to 5.35 mm wall is approx 0.7 ID is 4.3mm.
If you PM your address  can post it today.
CMS part description sounds like an apt description of Ronnie Pickering  ;D   .... and NO I don't know him!
cheers   ... Ash
« Last Edit: October 01, 2015, 11:16:02 AM by AshimotoK0 »
Offline Noelia
« Reply #18 on: October 04, 2015, 02:30:21 PM »
cheers   ... Ash
Hi Ash,
The plastic reserve tube fits perfectly!
Thank you very much for your help!
Thanks!
« Reply #19 on: October 04, 2015, 03:23:42 PM »
Top man Ash....
