Author Topic: CB500/4 carburetors  (Read 12418 times)
Offline jj205mi
Re: CB500/4 carburetors
« Reply #15 on: November 08, 2015, 05:55:55 PM »
well after having a think about it, i decided to do a compression test...
so between 85 and 110psi dry, a wet test seen them jump to 155 and 160psi, so thats a little worse, i guess its a rebuild on the top end.
Can anyone move this to the technical section?
« Reply #16 on: November 08, 2015, 06:07:33 PM »
Before you strip that down get it MOT'd and run it for a while as it could just be sticky rings that may well free off
« Reply #17 on: November 08, 2015, 06:22:10 PM »
Bryan is right, get it nice and hot, give it a good trash as it will loosen the carbon from the rings.
Offline jj205mi
« Reply #18 on: November 08, 2015, 06:30:42 PM »
it won't run well enough to take it anywhere lads, I've had it running a fair bit revving it out etc but still no joy. it can't hold an idle etc
« Reply #19 on: November 08, 2015, 06:42:11 PM »
Not ticking over will be the carbs or points on these old girls most of the time.
Offline jj205mi
« Reply #20 on: November 08, 2015, 07:46:12 PM »
The Honda manual says the compression to be 150-170psi, i thought the bike would be running poorly due to the lack of compression low down rpm. Damn points were before my time lol, i prefer electronic ignition and fuel injection all day.
ill have a look at the contacts, but i don't imagine it will run well with only half the compression it should have, you fellas will have more experience with these machines than me so as i said I'm open to suggestions.
