Author Topic: 550f1 engine removal  (Read 9608 times)
Offline shifter
« on: October 21, 2015, 06:14:12 PM »
Hi Guy's , can anyone tell me , is it possible to remove a 550 engine from the frame without removing the sump , I understand  removing breather cover would be necessary, also is it easier to lift out from left or right
" RIDDEN NOT HIDDEN"
 Moto morini 250 2c
Cb200
S90
Offline shifter
Re: 550f1 engine removal
« Reply #1 on: October 21, 2015, 06:30:45 PM »
Many thanks odd job, I didn't really wanted to disturb sump, but it sounds I have to , eh  cheers,
 Moto morini 250 2c
Cb200
S90
Offline JustcallmeMrT
« Reply #2 on: October 21, 2015, 07:00:37 PM »
I've had success removing the oil filter, breather cover and points cover, then  lay the engine on the right side on a nice soft surface (pillow) and lift the frame off of it.  Saves removing the sump, but not easy if the bike is fully assembled.
Offline matthewmosse
« Reply #3 on: October 21, 2015, 09:40:32 PM »
I always just pull the oil filter and breather cover, but then I am not the sort to worry about the paint and genrally have wanted the engine swapped inside a weekend. Also I wouldn't want to risk scoring the sump gaskett face when juggling an engine in a fully built up bike with no helpers around.
« Reply #4 on: October 22, 2015, 08:43:55 AM »
I managed to remove the engine on my 550 with the sump still attached, I just removed the oil filter housing and breather cover and it came out on it's side no problem. Also, as I'm standing here looking at the sump, I wouldn't sit the engine on the floor without the sump on as there is a little oil tube thingy, that looks like that would hit the deck and snap off. I will say, I did have to have help to actually lift the engine from the floor once out of the frame  ;D ;D ;D ;D
Offline Norniron
« Reply #5 on: October 22, 2015, 07:43:23 PM »
Hes useful for some things then julie 😉😉
1977 400 cafe
1972 500/4
2013 triumph STR675
« Reply #6 on: October 22, 2015, 08:20:28 PM »
 ;D ;D ;D ;D ;D Yes Dave, humping engines around is definitely his speciality
« Reply #7 on: October 22, 2015, 08:38:55 PM »
The engines sit nicely enough with the oil filter housing and sump in situ, and as my shed is a bit of a mess I normally stick the oil filter back on as soon as that bit is clear of the frame, but still supported, minimalising the chances for dirt or dust to get in. I have about 8 500/550 engines stood like this awaiting either work or installation. I also like a very basic engine stand I picked up in a job lot that allows me to test engines complete with exhaust without installing it.
Offline bomber
« Reply #8 on: October 22, 2015, 08:47:28 PM »
Matthew, any chances to see a picture of that engine stand?
One step forward, two steps backward...
Honda CB550F 1976
Offline shifter
« Reply #9 on: October 23, 2015, 07:15:49 PM »
Hi Guys, thanks for all your response and advice , yes it's out, managed  to keep sump on just removed top cover and oil filter, also a little wriggling, Happy Days.
 Moto morini 250 2c
Cb200
S90
« Reply #10 on: October 25, 2015, 01:43:55 PM »
I will try to get away from kids long enough to dig it out if possible, fraid shed time is set to be very limmited til the little horrors ( kids) start school, and that is a very long 2 years away  :'(
