CB750
Head gasket
Topic: Head gasket (Read 9279 times)
yozzer74
Head gasket
November 12, 2015, 05:19:23 PM »
Would anyone say it's worth buying this head gasket over the head gasket you get in David silver's gasket set . [ Guests cannot view attachments ]
bytio
SOHC Associate
Re: Head gasket
November 13, 2015, 01:40:35 AM »
Yes it would, the genuine Honda gasket is far better than copies and will greatly aid the prevention of oil leaks!
Trigger
Re: Head gasket
November 13, 2015, 08:43:44 AM »
It doesn't say that it is a Genuine Honda gasket, it states NOS! which could refer to any new old stock and the part number could be used as reference only. Lots of people listing parts like this on fleabay.
UK Pete
Re: Head gasket
November 13, 2015, 05:47:22 PM »
IT HAS THE CORRECT OVAL FIRE RINGS AND THE SEALANT ROUND THE CAM TUNNEL, SO IT COULD WELL BE HONDA, IF SO I WOULD BUY IT IF I WERE YOU, SEND THE GUY A MESSAGE AND ASK
PETE
Link to my Diecast K0 restoration
http://www.sohc.co.uk/index.php/topic,4827.0.html
Link to sandcast restoration
http://www.sohc.co.uk/index.php/topic,6862.0.html
bytio
SOHC Associate
Re: Head gasket
November 13, 2015, 06:30:29 PM »
I think it is the genuine one,
yozzer74
Re: Head gasket
November 13, 2015, 07:50:41 PM »
I've bought it we will find out. should have asked first I suppose .
yozzer74
Re: Head gasket
November 13, 2015, 07:55:29 PM »
It does say genuine in the description
Chris-freckle
Newbie
Re: Head gasket
November 13, 2015, 10:29:26 PM »
Hi I may be a bit old fashioned but I would not use anything other than genuine Honda gaskets unless Comedic ones are available.
Re: Head gasket
November 14, 2015, 09:06:10 AM »
Never seen funny gaskets but have seen cosmetic (i think you mean cometic)
bytio
SOHC Associate
Re: Head gasket
November 14, 2015, 12:28:14 PM »
Here is the genuine gasket about to be buttoned up
yozzer74
Re: Head gasket
Reply #10 on:
November 14, 2015, 12:31:53 PM »
Do you use any sealant on your base gasket
bytio
SOHC Associate
Re: Head gasket
Reply #11 on:
November 14, 2015, 11:19:29 PM »
No never used it on base or head gasket, make sure you use genuine Honda o rings as pattern ones are not thick enough and could get leaks. Also on the head, make sure the cam tower stud threads are sealed with thread sealant as some holes lead to the outside, was caught out by this on one rebuild and had to pull engine to redo.
bytio
SOHC Associate
Re: Head gasket
Reply #12 on:
November 14, 2015, 11:24:32 PM »
bytio
SOHC Associate
Re: Head gasket
Reply #13 on:
November 14, 2015, 11:24:50 PM »
These are the ones I mean
yozzer74
Re: Head gasket
Reply #14 on:
November 15, 2015, 12:03:57 AM »
Which ones the ones with the nuts on
CB750
Head gasket
