Author Topic: Not a SOHC question!  (Read 4152 times)
Offline MarkCR750
« on: November 28, 2015, 08:20:10 PM »
Not a Honda question but I'm looking for a bit of advice, I have fitted second hand hi level exhausts to my T250 but one of the exit pipes is slightly bent so I can't get the baffle in cos it won't line up with the support plates further inside the silencer, I've got a butane blow torch, do you think that will get the pipe hot enough for me to be able to bend it straight with an extension bar ?, the exit pipe is quite thin gauge steel approx 50mm O/D.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline MarkCR750
Re: Not a SOHC question!
« Reply #1 on: November 28, 2015, 08:55:12 PM »
Here's a photo, it's the exit pipe that I need to bend.
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
« Reply #2 on: November 29, 2015, 10:05:18 AM »
Last time I did something like that it took a torch on both sides to keep it hot enough. Enlist the help of a friend to hold both torches whilst you bend it. Should work okay.
Now you've put up a taster you're going to have to post some photos to show the rest of the bike. Good luck.
Offline MarkCR750
« Reply #3 on: November 29, 2015, 07:38:25 PM »
Thanks Roy, I used 1 torch but your right it needed 2 really, I got the bent area to orange and then used a 4 foot extension bar, after a few attempts it went, anyway success!, here's a photo.
« Last Edit: November 29, 2015, 07:52:35 PM by MarkCR750 »
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
« Reply #4 on: November 30, 2015, 06:31:02 AM »
Nice one on the exhaust. That's going to be a cracking little bike.
