Author Topic: Front fork assembly  (Read 5486 times)
Offline El__burro
Front fork assembly
« on: January 08, 2016, 06:04:11 PM »
Good year,
I have replaced the seal on both forks but I am in need of help.
I have followed a very easy process reassembly the inverse way as I disassembled it all.
My issue is the part in the picture number 14, its quite a thick ring between the seal and the circlip.
I have been trying to ensure that the circlip locks in its position but i am struggling, i have "punched it down" but not all the way; before I make a mess I thought I could ask for help.
please help!
El__burro
Re: Front fork assembly
« Reply #1 on: January 08, 2016, 06:38:14 PM »
Check the thickness of the new seals against the old as i think the later ones use modified thicker ones with no washer
Offline Green1
« Reply #2 on: January 08, 2016, 07:29:37 PM »
I used the thicker seals in my bike just discard the washer
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline El__burro
« Reply #3 on: January 08, 2016, 09:13:23 PM »
Actually the new seals are thinner than the old ones.
I guess removing the 14 will not cure the problem.
thanks
see images attached.
Offline El__burro
« Reply #4 on: January 10, 2016, 01:27:10 AM »
All sorted!  Thanks to perseverance and some scrap metal I had in the shed.
El___burro
« Last Edit: January 10, 2016, 05:57:26 PM by El__burro »
Offline El__burro
« Reply #5 on: April 04, 2016, 01:00:46 AM »
back to square 1.
Either because of the chinese seals I've used as replacement (wich is a tiny shorter) or probably because I made a mistake in replacing them..
the seller (of the chinese seals) has sent me a new pair, I will retry tomorrow but just to make sure I get it right this time...
The seals needs to face the road the left or the right way (see img)
many thanks
el__burro
« Reply #6 on: April 04, 2016, 06:42:31 AM »
The flat surface should be at the top
Offline El__burro
« Reply #7 on: April 25, 2016, 06:35:15 PM »
one is fine the other leaks, why?
el__burro
