Author Topic: 1977 CB550  (Read 65569 times)
Offline Valentinik
1977 CB550
« on: January 09, 2016, 10:51:13 PM »
Some will have seen my introduction post but if you haven't, First of all, this is the first bike i've owned and its a big learning experience more than anything for me, i've had numerous cars and I'm currently build a turbo westfield but bikes are something i have never worked on. So please excuse what some may feel are stupid questions.
Today i went and collected a new project. Its a 1977 CB550 K3, it looks like someone has changed the forks to super dream items as well as the wheels. Im hoping to find some good used items, refurbish them and replace them. As can be seen from the pictures, some bits are missing and its not in too good a state but something i thought was suitable to work on.
I went and collected the bike from leominster this afternoon. To pay my wife back for coming with me i had to take her out to dinner so wasn't able to start until we got back (she wasn't pleased).
Here it is before it was put in the garage:
I've removed the seat, tank and exhaust and just had a look at what exactly is missing and what i need to do:
One thing I'm not sure of what it is/where it is meant to fit is this:
Could anyone give me a pointer on what it is?
Mike
« Last Edit: January 09, 2016, 10:53:13 PM by Valentinik »
Offline Norniron
Re: 1977 CB550
« Reply #1 on: January 09, 2016, 11:24:58 PM »
Brake light switch that attaches to the rear brake lever
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Chris400F
Re: 1977 CB550
« Reply #2 on: January 10, 2016, 11:29:33 AM »
If you haven't already got hold of them I'd suggest getting a copy of the Parts List and Workshop Manual from here:
http://www.sohc.co.uk/index.php/topic,8884.0.html
Personally I have found a parts List to be far more useful than its name might suggest.
Online mickwinf
Re: 1977 CB550
« Reply #3 on: January 10, 2016, 12:24:23 PM »
if you need a bracket and spring I have new ones I was going to put on ebay.
Offline Norniron
Re: 1977 CB550
« Reply #4 on: January 10, 2016, 02:17:41 PM »
The brake light switch attaches to a bracket, on the 500 and I'm fairly sure the 550F it's a bracket welded to the frame, on the 550K however it went into a bracket which was separate and attached to the upper rear engine bolt, probably why it's loose as on the 500 and 550F you wouldn't really need to remove it. It's missing a long thin spring which goes through the hole in the pin you can see protruding from the switch.
If the carbs are missing I'd fit the carbs off either the 500 or the 550F as the 550K carbs were much different and TBH are pretty pants in comparison. You'd also need the airbox to match but it's a worthwhile change as the 550K carbs really are that bad.
Good advice from oddjob about the carbs.But u also have to change the intake manifolds on the back of the head.Your intakes wont line up with the older style carbs
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Valentinik
Re: 1977 CB550
« Reply #5 on: January 10, 2016, 03:50:25 PM »
Thanks everyone, its all really useful information to me, i've learnt so much already. Il keep an eye out for some carbs, the frame is the first thing I'm going to be working on though. So i've got plenty of time to gather the bits together.
I made a little bit of progress this morning. Both wheels are off, the engine is out and i've taken a look at the forks. The chrome seems to be pretty rusty and I'm not a fan of the wheels, so i may see if i can source a set of original forks and spoked wheels.
Before i took the engine out though i wanted to check it turns over as i didnt know what state it was in. The good news was it turned over quite freely. The less pleasing news was when i drained the oil, 2 litres of water came out before the oil.
As you can see from the picture theres a bit of rust on the camshaft and tops of the valves but I'm hoping its still useable. Im planning on a full engine rebuild anyway.
Mike
Offline matthewmosse
Re: 1977 CB550
« Reply #6 on: January 10, 2016, 05:30:35 PM »
Once you get inside the engine, check the journal bearings under that camshaft, have you got a rocker cover? Also check the valves are seated and not bent, Hopefully the water will not have been in there too long. I would think the twin disk setup and superdream front forks should be easy to re home.
Offline Valentinik
Re: 1977 CB550
« Reply #7 on: January 10, 2016, 09:31:20 PM »
Thanks guys, Is there a specific year of carbs/inlet I would be looking for?
Unfortunately I don't have the rocker cover. I think that is the reason for all of the water ingress, it seems like it has been left outside for a while.
Are the rockers and cover specific to the 550, or would a 500 set work if i can get them?
As I'm not going to get around to the engine build yet, i wondered if it would benefit at all to fill the engine with some fresh oil that i've got spare?
Mike
Offline Norniron
Re: 1977 CB550
« Reply #8 on: January 10, 2016, 10:57:30 PM »
http://www.ebay.co.uk/ulk/itm/311516677219
These are the carbs you want!
Im not personally recommending this set btw
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Valentinik
Re: 1977 CB550
« Reply #9 on: January 11, 2016, 03:41:42 PM »
That's great thank you. Il keep a look out for them.
Before I remove the wiring loom I'd like to test that everything works. However the ignition switch is faulty ( it's held together with a cable tie).  Is there a brand of switch that's ok to use? Or should I go with a genuine Honda item?
Offline Norniron
Re: 1977 CB550
« Reply #10 on: January 11, 2016, 05:41:06 PM »
1977 400 cafe
1972 500/4
2013 triumph STR675
Offline Valentinik
Re: 1977 CB550
« Reply #11 on: January 11, 2016, 08:44:33 PM »
This will do u Mike!
https://www.davidsilverspares.co.uk/CB550K3/part_28995/
Brilliant, ordered along with a spark plug spanner. I've decided to strip the engine down now and clean all the parts. Hopefully to try to protect them from any further damage. Just incase the water hadn't been in there too long.
Mike
Offline Valentinik
Re: 1977 CB550
« Reply #12 on: January 13, 2016, 08:10:46 PM »
My Ignition switch arrived today. So i hooked a battery up and tested everything. Everything seems to work, the only issue i can see if that the rear light is constantly on. The light switch has no effect on its operation, when the switch is moved the light flickers ever so slightly but nothing more.
Is there anything i could look at that may be causing it?
Mike
Offline MCTID
Re: 1977 CB550
« Reply #13 on: January 13, 2016, 08:21:31 PM »
If its a Canadian Bike (or perhaps a US Bike supplied to certain States) the lights are often linked to the ignition.....i.e. Ignition On = Lights On.
I had a Suzuki GT500 which I bought new in 1976 when I lived in Canada and that always ran the lights as soon as the Ignition was switched on........I had no problems with that set up but if I remember correctly it was the law at the time in Canada.
Worth looking into......maybe a UK market switch might solve the issue.
Offline Valentinik
Re: 1977 CB550
« Reply #14 on: January 13, 2016, 08:29:57 PM »
Thanks, that thought did cross my mind. Il take a look. When the switch is unplugged the light also stays on, i don't know if this makes any difference?
Mike
