CB750
Cam chain rivet link
Topic: Cam chain rivet link (Read 5183 times)
yozzer74
January 13, 2016, 07:29:38 AM »
Has anyone fitted a cam chain with a rivet link .and is it easy to do
Last Edit: January 13, 2016, 07:31:29 AM by yozzer74
mike the bike
CB400F, Royal Enfield Interceptor.
Re: Cam chain rivet link
January 13, 2016, 07:38:59 AM »
Done it on my 400. I used a split link to join the new chain to the old one, turned the crank until the new one is fed through, then used the soft link. I used a large hammer on the back as an anvil. The whole job only took an hour.
yozzer74
January 13, 2016, 12:30:27 PM »
January 13, 2016, 03:16:13 PM »
Only way to do it on a 450/500 twin and if its the same size chain there is a Honda part number
mike the bike
January 13, 2016, 05:09:51 PM »
The 500T has the correct size soft link
Trigger
January 13, 2016, 09:14:05 PM »
Easy to do if you know what you are going
yozzer74
January 13, 2016, 10:16:40 PM »
It wasn't really doing it that was the issue. it was if it was safe to do .wasn't sure if you could have a rivet link in it .
January 14, 2016, 07:08:59 AM »
They are all riveted originally----don't magically arrive in one piece from the engineering dimension
yozzer74
January 14, 2016, 07:17:04 AM »
Very true but they will have a machine doing it .
CB750
