Author Topic: CR carbs  (Read 17311 times)
Offline bladeboy
CR carbs
« on: January 13, 2016, 07:39:19 PM »
Hi, I'm thinking of fitting a set of 29mm CR carbs to my 78 cb750,
Can anyone advise me if it's a good idea or not... Cheers
Re: CR carbs
« Reply #1 on: January 14, 2016, 07:07:11 AM »
Not for normal road riding no
Greebo
Re: CR carbs
« Reply #2 on: January 14, 2016, 12:14:19 PM »
I look into this a couple of years ago before building my CB 750 K6 café racer, so I agree with Bryanj stick with the stock carbs especially if its a standard engine [not tuned]
CR carbs can even cause unreliability for race tuned engines, they are also difficult to ajust in situe.
I finished up putting K&N filters on mine [stock motor] along with re-jetting which took a bit of sorting, but it goes like stink now.... ;D
Offline bladeboy
Re: CR carbs
« Reply #3 on: January 14, 2016, 09:46:35 PM »
So stick with standard carbs but re jet them .... I was going to put a yoshi cam in her bad idea or not??? Such a grey area thanks for yr input guys.
Re: CR carbs
« Reply #4 on: January 15, 2016, 06:44:29 AM »
Yoshi cam on its own don't work, you need to make ignition timing mods and jetting mods plus gearing mods as the power is all at the top of the rev range
Greebo
Re: CR carbs
« Reply #5 on: January 15, 2016, 11:13:00 AM »
Don't play around trying to tune the engine you will have a headache with reliability, theses engines dont like tuning, unless its done by a sohc professional specialist & then it would only be good for the track.
I put K7 carbs on my K6, only because the originals were knackered & I'd got a good set of K7 carbs, fitted 138 main jets, needle is on last notch [bottom]  ignition timing advance 10 degrees, more power & it runs like a dream.
I have a full spare set of K&N filters as new for sale [for the K6 carbs]
Offline onethumb
Re: CR carbs
« Reply #6 on: January 15, 2016, 05:24:09 PM »
Sorry to hijack but I've got the PhD carbs on my 750 f2 and will be putting cone filters on what jet size should I go to or should I just clean every thing up?
Also is there a rebuild link for the PDFs carbs anywhere?
Thanks again, steve.
« Last Edit: January 15, 2016, 05:26:09 PM by onethumb »
Offline onethumb
Re: CR carbs
« Reply #7 on: January 15, 2016, 05:27:09 PM »
Sorry admin but idiot know how to split the quote thing up. My bad.  :-\
Offline yozzer74
Re: CR carbs
« Reply #8 on: January 15, 2016, 07:49:54 PM »
There's rebuild kits on eBay for them and David silver's do them
Re: CR carbs
« Reply #9 on: January 15, 2016, 09:04:18 PM »
PhD Carbs?  You need a university education to understand them!
 8)
Re: CR carbs
« Reply #10 on: January 15, 2016, 09:08:09 PM »
It's not particularly intuitive to the modern iOS generation...  I was brought up on Fortran, Algol and HTML so can edit the code in the "quote"
The trick is to remove any unwanted text from within the [quote and /quote] tags - I can't use the full syntax here or it would treat them as quotes!
 8) You can also edit quotes so that you can quote what the originator never said  8)
eg
Steve, I think you are a biking god!
Re: CR carbs
« Reply #11 on: January 15, 2016, 10:18:24 PM »
 ;D ;D ;D ;D
PHd  carbs ' They won't let you down, won't let you down again'    ;D ;D ;D
Offline onethumb
Re: CR carbs
« Reply #12 on: January 15, 2016, 11:35:08 PM »
Bloody hell, I've got to start proof reading my posts from now on.
Steve I think you are a biking God.
Re: CR carbs
« Reply #13 on: January 16, 2016, 07:40:51 AM »
Clearly my Algol/html stuff is meaningless today as this doesn't work at all using Tapatalk on my iPhone.
Read it on a PC.
Offline UK Pete
Re: CR carbs
« Reply #14 on: January 16, 2016, 08:34:22 AM »
[/quote]
 8)
[/quote]
