Author Topic: PD carbs  (Read 4842 times)
Offline onethumb
PD carbs
« on: January 17, 2016, 10:58:48 PM »
Hi all,
I'm going to be fitting cone filters and a non stock exhaust to my 1978 F2 sohc, so will have to re-jet, because i dont know what size I need and there will be some swearing and messing, can any one point me in the direction of a Uk supplier of a jetting kit  with several sizes in?
Any tips or tricks would come in handy.
thanks again
Greebo
Re: PD carbs
« Reply #1 on: January 18, 2016, 10:51:25 AM »
Hi all,
Quote:
You can get the jets from NRP Manchester Phone 0161 832 8646 [I think its Andy]
The only problem is this guy has not got much patience especially if you are not sure of exactly what you want, I found him quite ignorant, but eventually I got what I wanted.
Good Luck
Offline onethumb
Re: PD carbs
« Reply #2 on: January 18, 2016, 06:11:02 PM »
Cheers buddy. I'll check them out.
Has anybody used the sigma 6 jetting kit?
Thanks. Steve.
Offline onethumb
Re: PD carbs
« Reply #3 on: January 21, 2016, 10:20:44 PM »
Hi all,
Has anyone got a picture of the way the choke springs locate. I'm a bit stuck with it. Instructions or picture explosions would also be a help. I've used a Haynes manual but the pics especially for the 1978 f2 are shocking.
Thanks. Steve.
Offline onethumb
Re: PD carbs
« Reply #4 on: January 26, 2016, 08:33:05 AM »
Hi all,
Got to the bottom of it. The small choke spring needs to loop round on its self to give it the tension to move the 3 & 4 butterflies. Sorted
Hope this helps others.
Steve.
