Author Topic: Primary Chain + F1 forks  (Read 13017 times)
Offline Seabeowner
Re: Primary Chain + F1 forks
« Reply #16 on: January 21, 2016, 12:37:40 PM »
Just my luck.
Lower rear engine mounting 12mm. Ideal for using as slide hammer to withdraw primary shaft.
Swinging arm is 14mm
Rear axle is 18mm
Nothing on bike 16mm that I can fid.
And to cap it all. Yes I was looking at the tool on ebay but thought the 4-way device would be a better investment. David Silver sell an aftermarket one for about £25. It has been OOS for a while and I got fed up with waiting and ordered a load of stuff from him on Monday and did not bother to put it on back order as I thought I could not wait.  Stuff arrived Wednesday and yesterday they tell me the tool is back in stock and they charge £5.85+Vat for dely!!
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #17 on: January 21, 2016, 04:42:53 PM »
You wana bring it to Gloucester i'll take it off for nowt!!
Offline Seabeowner
« Reply #18 on: January 24, 2016, 05:59:30 PM »
Thanks Bryan, but a little far. I'll get the DS tool. At least it will have a re-selling value.
Offline Gixxer-18
« Reply #19 on: January 24, 2016, 06:32:09 PM »
Before you spend, a CB350/4 rear axle works as a puller for the CB500/4 Rotor. Use the wheel spacers as the slide hammer. The Puller for the 350/4 I used was an M18x1.5 bolt., or if you haven't got the CB350/4 Axle, an M16x1.5 bolt is cheaper than the Honda tool!
Regards,
Nigel.
Offline Seabeowner
« Reply #20 on: January 28, 2016, 04:55:55 PM »
Was looking at buying a bolt, but tool looks as if thread is turned off first couple of mm for location. Wheel bolt for Fiat Van is correct thread, amongst others I imagine. May try that.
