Author Topic: fitting new suspension fork boots  (Read 5332 times)
Offline theof
« on: January 25, 2016, 10:54:45 AM »
Hi,
I've replaced the fork boots on my K6 as the old ones were cracked. Forks disassembly was easy, lowers dropped out of the crowns fine. But now I'm struggling to fit the boot over the fork lowers, to create a seal.
Has anybody found a good method for doing this. I think I might need to soften the rubber boots somehow, perhaps in boiling water?
Any tips would be great.
Thank you,
Theo
Offline Sgt.Pinback
Re: fitting new suspension fork boots
« Reply #1 on: January 25, 2016, 12:13:37 PM »
I've just done this with a small screwdriver. Did you buy genuine HONDA parts?
cheers, Uli
« Reply #2 on: January 25, 2016, 04:52:08 PM »
Hair dryer softens the rubber boots for a easy fit ;)
« Reply #3 on: January 25, 2016, 07:54:04 PM »
Dunk them in V hot water for a few minutes .  Use red rubber grease or silicon spray/grease.  I'm always having to persuade hoses onto fittings at work.
« Reply #4 on: January 26, 2016, 06:27:36 AM »
WD and a thin screwdriver plus patience to work them round
Offline theof
« Reply #5 on: January 26, 2016, 03:28:15 PM »
all, thanks for the tips.
they are Honda / OEM boots, but they are old and have stiffened up. will try the heat, lube and screwdriver methods. but maybe i need new Honda / OEM ones which have more flexibility in them.
cheers
Theo
Offline Chris400F
« Reply #6 on: January 26, 2016, 03:40:52 PM »
If they have stiffened with age to the point where they are difficult to fit is it likely that the same stiffness would also cause them to quickly crack in use?
Offline Sgt.Pinback
« Reply #7 on: January 26, 2016, 03:52:17 PM »
When they are old put them in the dishwasher. Don't ask your wife.
cheers, Uli
