CB350/400
Gearbox blanking seal.
Topic: Gearbox blanking seal. (Read 13185 times)
royhall
Keep biking I'm not quite bankrupt yet
February 12, 2016, 04:44:32 PM »
Is it possible to change the main shaft oil seal (34x9mm) on a 400F without splitting the cases. Its the seal that is a blacking piece with an oil supply right underneath (just in front of the sprocket). My mates bike is weeping oil past this seal. Funny, I was only talking about that same thing 2 days ago, think I will also check that seal on my 350F.
Last Edit: February 12, 2016, 07:30:08 PM by royhall
Bodd
SOHC Member
Re: Gearbox blanking seal.
February 12, 2016, 07:57:15 PM »
Do you mean this ?
CB400 F1 Café build
http://www.skylinesoftware.co.uk/400four.html
RD250E Restoration
http://www.skylinesoftware.co.uk/rd.html
Current project
http://www.skylinesoftware.co.uk/tracker001.html
mike the bike
CB400F, Royal Enfield Interceptor.
February 12, 2016, 08:26:38 PM »
I'm sure that seal's got a locating tab sticking out and possibly a flange as well to keep it firmly located. Whereas removing it with a screwdriver is do able, refitting the new one is an unlikely prospect without opening up the crankcases a tadge.
Bodd
SOHC Member
February 12, 2016, 08:30:36 PM »
It has got a tab sticking up but no flange (No 272 in the picture), I suppose how flexible it is will determine if it will go in without splitting/lifting the cases.
CB400 F1 Café build
RD250E Restoration
Current project
royhall
February 12, 2016, 08:35:52 PM »
That's the one Bodd. If its the same as the 350F it definitely has a dowel shape tab on it.There's a quite large weep of oil coming out at about the 5 o'clock position, right about where the oil feed is under the seal. Do you know of anybody that has successfully changed that seal without a stripdown, or a way of re-sealing it in situ. Don't mind helping him with a seal change but I don't want to get involved in his stripdown, don't have the time at the moment. Think I will get him to order a new seal then I can have a look at how flexible they are etc. Cheers.
Last Edit: February 12, 2016, 08:38:50 PM by royhall
Bodd
SOHC Member
February 12, 2016, 08:53:47 PM »
I don't know if anyone has ever replaced one in situ but if it was me I would give it a try, it looks like the tab isn't too big or too far from the edge so I would put it in at an angle locating the tab first then tap it into place, I would also put a smear of Hylomar on it.
CB400 F1 Café build
RD250E Restoration
Current project
dave400
SOHC Expert
February 12, 2016, 09:53:07 PM »
I'm sure that plug is rubber formed over a metal cup, I remember it was not very flexible when I replaced it during my 400 engine rebuild....it will probably be a job and a half putting a new one in and not deforming it.
Bodd
SOHC Member
February 12, 2016, 10:06:56 PM »
You are right about the metal cup dave400, this is what it looks like on the DS website, I would still be tempted to have a go though.
CB400 F1 Café build
RD250E Restoration
Current project
February 13, 2016, 10:27:44 AM »
Sorry not worth wrecking a gearbox trying to do a half assed job
Bodd
SOHC Member
February 13, 2016, 10:40:27 AM »
How is it going to wreck the gearbox ? It doesn't move, doesn't affect any moving parts and if nothing leaks past it it is doing it's job.
CB400 F1 Café build
RD250E Restoration
Current project
royhall
Reply #10 on:
February 13, 2016, 11:04:03 AM »
Replacing the leaking crank seal on my 350F (that I stupidly put in the wrong way round) was a half assed job, but it worked a treat. Surely got to be worth a try at the cost of a seal just as long as were very careful. If it doesn't work the engine was coming out anyway, he cant use the bike as it stands.
Bullit
SOHC Member
Reply #11 on:
February 13, 2016, 02:46:17 PM »
If it's just a blanking plug does the dowel need to be there? Could it be dremel'd off???
mike the bike
Reply #12 on:
February 13, 2016, 06:32:47 PM »
Don't see why not. I would avoid using Hylomar in this instance in favour of 'Sticks like Sh*t' (from Screwfix) because of its superior adhesive qualities. If that plug loosened itself while you were riding it would spoil your day.
Reply #13 on:
February 13, 2016, 11:24:58 PM »
If its in wrong it afdfects the oil flow thats why the peg
Bodd
SOHC Member
Reply #14 on:
February 14, 2016, 09:21:20 AM »
How can it affect the flow ? It's a symmetrical cup.
CB400 F1 Café build
RD250E Restoration
Current project
CB350/400
