Author Topic: CB750 KO - matching number  (Read 7152 times)
Offline Sgt.Pinback
« on: February 16, 2016, 05:39:03 PM »
VIN and engine 1019861.
Never seen this.
DC -  KO in trendy look for US $ 14.800,00
http://www.ebay.de/itm/Honda-CB-/111903783817?hash=item1a0dfc3b89:g:BHkAAOSwuAVWvx5m
cheers, Uli
Re: CB750 KO - matching number
« Reply #1 on: February 16, 2016, 06:28:43 PM »
That is not a sandcast and I have never seen matching numbers in my 27 years of building these engines ;)
« Reply #2 on: February 16, 2016, 06:52:50 PM »
About as sandcast as my cat, if it really has matching numbers it could be a ringer, done by someone who didn't know any different.
Sadly I don't see a $14k cafe racer, just a huge mental list of all the bits you'd need to make it right, but then that's me these days.
« Reply #3 on: February 16, 2016, 08:30:20 PM »
How come it's from California and the advert is all in German?
Offline Aly-b
« Reply #4 on: February 16, 2016, 08:46:07 PM »
Scam?
Offline Chris400F
« Reply #5 on: February 16, 2016, 09:09:13 PM »
Most likely because it is on German eBay (.de).
Here's the same bike from American eBay (.com).
http://www.ebay.com/itm/Honda-CB-/111903783817?forcerrptr=true&hash=item1a0dfc3b89:g:BHkAAOSwuAVWvx5m&item=111903783817
« Reply #6 on: February 16, 2016, 09:20:55 PM »
Now you've made me see this, a 1969 K0 CB750 diecast barn find in Candy Blue Green, wrinkle tank, double cut fenders. I want. Unfortunately it's out in the middle of nowhere,  Clarkston, Michigan USA. Buyer is responsible for vehicle pickup or shipping.
http://www.ebay.com/itm/Honda-CB-/272134367739
However I did notice this little gem in the small print.
Quote
Engine is stuck and if your not aware, these barn finds have over a 95% chance of being freed up with a breaker bar on the crank.
Please Greg, stay away from the bike with your breaker bar. It's called that for a very good reason.
« Last Edit: February 16, 2016, 10:03:37 PM by MrDavo »
« Reply #7 on: February 17, 2016, 07:10:54 AM »
The only way the numbers can match is
(1) its a Ringer
(2) the crankases were replaced and whoever did it stamped the wrong numbers into it
I would want detailed pictures of both stamped numbers and then at leat three decimal points knocked off cos its orrible
Offline Sgt.Pinback
« Reply #8 on: February 17, 2016, 08:13:38 AM »
Couldn't it happen by accident and whats a Ringer?
cheers, Uli
« Reply #9 on: February 17, 2016, 08:17:36 AM »
A ringer is an English term for a stolen vehicle that has had it's identity changed (vin and engine numbers) to make it appear legal.
« Reply #10 on: February 17, 2016, 08:24:34 AM »
I did not know that. I learn something new on this forum every day ;D ;D
So, what is a dead ringer ? Is that a stolen bike that will not start ???
Offline Sgt.Pinback
« Reply #11 on: February 17, 2016, 08:37:23 AM »
Thanks.
That's an interresting bike (for me), because VIN 16217 is just some numbers higher than my bludgreen KO.
This one seems here to be a very genuine bike.
 What I see is:
- production date of my 16.0xx  is def. 12/1969
- double cut fender WITH speedo cable guard is correct on mine
What makes me wonder:
- wrinkle tank on 16.217 with chrome trim without black line . But no wrinkle tank with trim with black line on my 16.0xx
I am pretty sure that my bike has still the original tank. My theory is, that there was a second supplier for the tanks when production raised. This supplier made no- wrinkle tanks and took over total tank supply after a while. At least with K1.
- recessed ignition switch on 16.217
Again, my 16.0xx doesn't have it.
Maybe same as with the tanks? As with the tanks there are no different part-numbers for the KO ignition switches in the parts book.
« Last Edit: February 17, 2016, 08:39:03 AM by Sgt.Pinback »
cheers, Uli
« Reply #12 on: February 17, 2016, 09:38:59 AM »
My10/69 diecast doesn't have a wrinke tank / never did from new out of the dealers, according to the original PO. It had a non-stripe silver trim (original) and an alloy 'Antimon' fuel cap that had the original rivet pins in it with no sign it had ever been changed, as you have to de-peen or drill them to remove them, which is always obvious. Work that one out the VIN is 10103XX (UK bike). I often wonder if it was damaged in transit but unlikely as the same dealer registered another K0 on the same day, one reg No. up from mine. He was one of Honda's star dealers at the time and won trips  to Japan 'cos he sold so many bikes .. I guess they were mainly C100/C50 chicken chasers to local factories... so he must have got his hands on two K0's from the first batch of 20 bikes imported by Honda UK to 'test the water' after poor CB450 twin  sales over here. Sadly the other bike is on the DVLA database but unreg'd for yonks so probably long gone now.
Offline Sgt.Pinback
« Reply #13 on: February 17, 2016, 01:57:08 PM »
That proves my theory, as my later 18.9xx (01/70) has a wrinkle tank. And a recessed ignition switch.
Does your 12/69 has the recessed ignition switch?
cheers, Uli
« Reply #14 on: February 17, 2016, 02:20:52 PM »
Recessed ignition switch, black kill switch etc. Everything apart from wrinkle tank Uli its 10/69 not 12/69
« Last Edit: February 17, 2016, 04:43:33 PM by AshimotoK0 »
