Author Topic: CB750F1 wheel alignment.  (Read 7975 times)
Offline Skoti
« on: February 26, 2016, 01:55:19 PM »
Hi,
just done a wheel alignment check on my CB750F1 and discovered the front wheel is 10mm off set to one side.
I used two straight lengths of metal held up against the rear and front wheels, measuring the off set at the front wheel.
Maybe this would account for the low speed steering wobble when cornering to the right?
Any thoughts on the  likely cause of this problem would be greatly appreciated.
Regards
Skoti.
Skoti
1976 Honda CB750F1
Re: CB750F1 wheel alignment.
« Reply #1 on: February 26, 2016, 04:46:00 PM »
only three possible reasons
(1) wheel spacers in wrong positions
(2) bent frame
(3) wheel(s) built wrong
Offline Skoti
« Reply #2 on: February 26, 2016, 05:48:52 PM »
Thank for your reply.
(1) I checked the wheel spacers and front wheel spindle all OK.
(2) I had a visual examination of  the frame, it seems OK. But in what area would I expect to find damage?
(3) Honda man's comments below on CB750 wheels suggests they are built wrong!
 Maybe this is the answer to the problem?
Honda man writes this:-
Here's the whole story of how "Jimbo" Jim Chamberlain and I first "discovered" the front wheel offset phenomenon, the related head shake, and the fix:
Jim had a K0 sandcast bike, one of the very first in Central Illinois. He wanted a dual-disc setup, like he saw at Daytona in 1970. But alas, his early K0 only had the mounts for a disc on the left side fork. The K1 had just come out in 1970 with forks that could fit 2 discs (specifically so Honda could use them at Daytona), if you made your own right-hand triangle mount (all you needed was the lefthand one and some washers and a file to make one). This was all happening just as I had started working with him in the Peoria shop, Brown's Sport Center Honda. A friend of his came in to buy a 750, and Jim talked him out of the dual-fork setups, paying the guy an undisclosed amount of cash, then swapping the front ends between the bikes. Upon his first test drive, Jim noticed the new headshake phenomenon, pronounced because his front tire was also somewhat worn, as he had promised the other guy would still get his new tire and had dutifully swapped tires, too. So, the following weekend, as a test, Jim put a new tire on his: the headshake remained. When his friend's bike came in for the 500 mile maintenance, Jim talked him into a "swap-back" test: suddenly Jim's K0 had the old forks and wheel back (with a new tire from the newere bike) and the wobble disappeared. Jim wanted the 2-disc setup badly enough that he swapped it all back to the original agreement, and the K1 owner rode off, never knowing how much better his bike handled than most K1 bikes.
In the swapping process, we did notice the wheel rim was closer to the fork on the disc side, though. So, a few weeks later, Jim retrued the wheel over to the middle, guessing it at 4mm difference, using the fender's center as "reference". The headshake disappered instantly. This posed a different problem, though, when his 2nd disc arrived: the reversed caliper had alignment problems, hitting the disc at an angle, and scraping the rim sometimes. So, he offset the wheel back the other way about 2mm ("split the difference") and filed away the offending corner of the caliper. In the end, he swapped the forks around and ran the calipers behind the fork legs to reduce the heavier feeling that the extra caliper adds to the steering when it is "up front". In our last discussion on the topic, he believed that one day, when it wasn't college finals season, he was going to realign the rim back over to center, to see if he could get away with it in the corrected location and with reversed calipers. It was about then that I moved to Macomb, and I never talked with him again, except by a couple of letters, regarding transistorized ignitions like the ones I build now: that was THEIR beginning, circa 1972.
So, like I told McRider: it's a long story, but true, and out in plain sight: if you can find a sandcast bike's owner with the asymmetric forks, we could maybe find out the distances between the wheel rim and the inside of the forks, both sides, and compare that to the later bikes. You'll probably find them to be off about 3mm or so, toward the disc side, on the later bikes, and more even on the early ones. Be sure to discuss wheel bearing slop with the K0 owner (i.e., make sure there isn't any) and  and make sure the fender is not used for reference here, as most of them get bent and twisted with fork activity over the years, so they are not centered any more. Try to find a good way to masure it: that's often hard for the novice who wants to use a ruler instead of long-head calipers or transfer verniers. I have not yet met a K0 owner here at SOHC4 who is also "machinist" enough to have the tools needed to make the measurements.
Skoti
1976 Honda CB750F1
« Reply #3 on: February 26, 2016, 06:11:15 PM »
An offset front wheel would be obvious to spot because of the proximity of the mudguard.   If you are measuring an offset comparing it to the rear wheel,  it may be that the rear wheel is offset instead, possibly caused by the spacers in the wrong order.  An easy mistake to make on some bikes.
Offline Erling
« Reply #4 on: February 27, 2016, 12:30:19 PM »
Like asked above I refitted the original front wheel to my Sandcast now more than 46 years after it was changed for a 10" Münch drum brake off my previous BMW.
It fits exactly in the middle of fork legs. Measured with a piece of edge shaped 6mm plywood.
It is not possible to fit the axel from wrong side without the disk touching left fork leg.
By the way fork legs look mirror to one another with logs.
Above said right leg had no logs for a second brake.
Erling.
Offline Skoti
« Reply #5 on: February 28, 2016, 01:52:11 PM »
I dismantled the front end to check the fork stanchions and yokes for damage, all seem fine so I reassembled and checked the front - rear wheel alignment once more.
This time I used a lengths of angle iron instead of the metal tubing and guess what? the alignment checks out OK!
Sorry for wasting every bodies time with my nuisance posts.  :-[
Skoti
1976 Honda CB750F1
Offline Erling
« Reply #6 on: March 02, 2016, 09:39:49 AM »
But you have still for a wobble to the right?
Offline Skoti
« Reply #7 on: March 02, 2016, 10:18:47 AM »
Due to snow there's not much chance to road test for wobble.
I've turned my attention to the front wheel now and notice a very slight imperfection where the rim weld joint is.
The wheel runs true when spun up but you can detect a recces where the weld joint is on the right hand side of the rim which seems to transfer to the tyre by the way of a very slight kick.
It has an oversize tyre fitted (100.90-19) which I intend to replace with a 3.25-19.
The wobble only occurs when more weight is transferred to the front end as I'm riding down steep mountain passes through tight right hand bends with the throttle closed off.
Skoti
1976 Honda CB750F1
« Reply #8 on: March 02, 2016, 01:45:27 PM »
All rims have a "kick" where the rim is welded but if it is in good order the tyre should not kick
Offline Skoti
« Reply #9 on: March 02, 2016, 03:32:25 PM »
Thanks for that info regarding the wheel rim.
Just ordered a pair of Bridgestone Battlax BT-45 tyres 3.25-19/4.00-18 to replace Avon Roadriders which were prone to cracking between the tread pattern, so I will see if the Bridgestone tyres reduce the wobble problem.
Skoti
1976 Honda CB750F1
