Author Topic: Dresda Restoration  (Read 30161 times)
Re: Dresda Restoration
« Reply #15 on: May 17, 2016, 04:40:44 AM »
Take the primary shaft out and build everything in the top half fitting the primary shaft through AFTER case assembly
Offline masonmart
« Reply #16 on: May 17, 2016, 09:24:51 AM »
Ow!! The primary shaft is in and it was a very hard job getting it in through the starter clutch, etc., I don't fancy taking it out again but I'll have a look. I followed the manual
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
« Reply #17 on: May 17, 2016, 04:32:02 PM »
If it was difficult to fit you were doing it wrong they should slide in easy except for a light tap at the very end, this one of few cases where the manual is not exactly right on the easiest way
Offline masonmart
« Reply #18 on: May 17, 2016, 05:44:26 PM »
It's all together and seems OK. Is there a simple way of checking that the gears work?
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
« Reply #19 on: May 18, 2016, 06:12:07 AM »
Just turn the selector drum BUT you will probably need to turn both shafts at the same time whilst rotating the drum(3 hands required)
Offline masonmart
« Reply #20 on: May 18, 2016, 07:10:10 PM »
Got this far with the engine today after coating, everything working OK.
Found that I couldn't bottom the bolts for the starter motor and then that it was full of what looked like some kind of blasting solids. Disaster because it was supposed to be soda blasted or if not then all oilways blocked off. Stupidity on my part because it'll have to come apart again to make sure that it's really clean. A real lesson learned there.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Offline masonmart
« Reply #21 on: June 02, 2016, 07:21:00 PM »
Well, after two back to square ones because of poor preparation 9by me) the engine is done. Hope to wrap the frame around it next week and assemble all of the cycle parts which are now coated
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Offline MarkCR750
« Reply #22 on: June 02, 2016, 10:07:36 PM »
Looking smart too, (back to square ones just gods way of telling you to read the manual).
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline masonmart
« Reply #23 on: June 03, 2016, 09:44:00 AM »
Too true Mark.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Offline masonmart
« Reply #24 on: June 03, 2016, 03:47:49 PM »
Today I unpacked the frame, swinging arm, forks and engine plates and bolts ready for assembly to make sure that I have all of the bits.
I stripped the forks down to check the internals and polish the bottom halves and guess what? Yes, the stanchions are bent and pitted in the area that will pass through the seals. Never mind, new OEM stanchions are only £200 each plus P&P. Any ideas on where I may be able to get hold of a pair of straight ones or does anybody have a pair to sell.
These are the hubs, black to look good with polished alloy rims. Sat for 2 hours polishing the rims, hard work.
Dresda lightweight frame, tiny thing.
Dresda swinging arm with the engine plates which I managed to get reasonably well polished. I'm 2 engine bolts short but will make them next week.
Very disappointing day because of the forks but a case of I get knocked down but I get up again. Sounds like a good title for a song if somebody hadn't already done it.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Offline petermigreen
« Reply #25 on: June 03, 2016, 03:55:01 PM »
For less than the price of replacement stanchions, Philpotts in Luton can straighten and re-chrome including collection and delivery. I've had 2 sets of stanchions re/chromed and they're very good. Check them out www.pittedforks.co.uk
Peter
« Reply #26 on: June 03, 2016, 04:06:24 PM »
I agree with Philpotts as there are at least 3 different types of leg and you have to get the right ones.
Also read the manual and check the parts book BUT do not take them as gospel as misprints happen(especially Haynes) and according to Honda there are 4 gear change forks!!! DUH. I am getting older and slower, just like my 'puter soanswers take longer but they will get there.
On your nicely painted frame and brackets, make sure that the coating is removed to bare metal where the earth cable goes(and the engine side) plus where the coils mount there should be a small ground lead where the coating also needs to be removed or you will melt the loom
Offline haynes66
« Reply #27 on: June 03, 2016, 04:47:38 PM »
can you guys slow down with your restorations please!! i'm still at the collecting bits and listing stage. nice work though.
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline UK Pete
« Reply #28 on: June 03, 2016, 05:13:59 PM »
I know exactly what you mean    pete
Offline MarkCR750
« Reply #29 on: June 03, 2016, 07:01:56 PM »
Another benefit of having the forks restored is that you get a far thicker layer of chrome which resist corrosion and wear better than OEM.
PS do you know how much lighter the Dresda frame is?.
« Last Edit: June 03, 2016, 07:04:09 PM by MarkCR750 »
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
