Author Topic: Wiring  (Read 5708 times)
Offline yozzer74
Wiring
« on: March 02, 2016, 09:27:46 PM »
Hi does anyone know best place to buy wire & connectors for making wiring harness.cheers
Offline gtmdriver
Re: Wiring
« Reply #1 on: March 02, 2016, 10:05:19 PM »
Re: Wiring
« Reply #2 on: March 03, 2016, 07:38:28 AM »
+1.  That's where I get all my stuff from.
Re: Wiring
« Reply #3 on: March 03, 2016, 08:00:33 AM »
-1 on that one .....  Lots of Hondas like the CB750 use 3.5mm Bullets not 3.9 and they are much  rarer. I used to get those plus the Hitachi 6.3mm blade connectors (eg CB750 Alternator plug & socket) and glossy silver and black PVC sleeving from Vintage Connections in the States but I placed an order a few weeks back and he cancelled my order as I don't think he ships here any more BUT he pointed me to another place PLUS ...  I found the 3.5mm bullets in Hong Kong Mega cheap and no customs charges.
http://vintageconnections.com/  (cancelled my order)
Here are the 3.5mm bullets and they are good quality and fast delivery. they are not tin plated but neither were the originals or the ones from vintageconnections.
http://www.ebay.co.uk/itm/191428132791?_trksid=p2057872.m2749.l2649&var=490524904619&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/191428132791?_trksid=p2057872.m2749.l2649&var=490524904620&ssPageName=STRK%3AMEBIDX%3AIT
New Supplier Link :-
http://www.cycleterminal.com
"Subject:
Vintage Connections
Note:
We are unable to fill and ship your order. This is a full refund. You might want to try ordering your sleeving from http://www.cycleterminal.com. They offer the same gloss black and silver-gray sleeving items that we do.
ANYONE KNOW A SOURCE OF THE ROUND MULTI-PIN BROWN CONNECTOR USED ON HONDA IGNITION SWITCHES (CB750,CB500,CB250/350K)
« Last Edit: March 03, 2016, 08:47:02 AM by AshimotoK0 »
Offline yozzer74
Re: Wiring
« Reply #4 on: March 03, 2016, 08:52:11 AM »
Thanks for the links .also any opinions on coils .are those cheap ones on eBay any good .
Re: Wiring
« Reply #5 on: March 03, 2016, 12:52:39 PM »
A lot of pattern coils are much lower resistance than standard so if you are using points they can be taking up to double the standard current which will reduce points life considerably. To be the same as stock Honda they should by typically around just less than  5 Ohms primary  DC resistance. Same basic coil on all SOHC 4's
Offline gtmdriver
Re: Wiring
« Reply #6 on: March 03, 2016, 06:23:26 PM »
The OEM coils on my CB350F were 4 ohm and the replacements from DS were only 2 ohm. While this is workable, if not desirable, with contact breakers it is unacceptable with some electronic ignitions. Boyer Bransden specify 4 ohms minimum.
I ended up wiring ballast resistors in series with the power supply to each coil.
watty51
Re: Wiring
« Reply #7 on: March 04, 2016, 07:57:13 PM »
Cant understand why DS are selling these coils if they are no good. Just purchased a couple from DS and put them on my cb350f. I'm still running points, will they be okay or should I bin them ?
