Author Topic: Final drive/output shaft problem  (Read 5312 times)
Offline RGP750
« on: March 06, 2016, 08:35:37 PM »
750 k0 Output shaft
I have a problem with bearings/ shaft please see photos i think they may help.
I have a larger bearing fitted than standard and also have what i think to be the correct bearing
but the id is smaller than the shaft fitted,Is it a later shaft???
It had been bodged (see the pin)
Was it's size increased in later bikes??
if so does anyone have an original for sale.
Rich
« Last Edit: March 06, 2016, 08:37:31 PM by RGP750 »
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Re: Final drive/output shaft problem
« Reply #1 on: March 06, 2016, 09:05:23 PM »
See my emails Rich but the later double row bearings was fitted to K7 possibly K6  and k4 If it's the shaft assembly /gear assembly then I have a low mileage one from a K1 the only difference is that one of the bearings is not grooved on the K1 ? I imported the shaft and two complete low mileage early gearboxes for my k0 as I was undecided on the state of my gearbox dogs on the gears. All of  the gearbox clusters on UK eBay were worn & overpriced sh#te at the time
Think double row bearing K3 onwards but we never got that model so unsure on later euro. k2s the later bearing is 5206 I think
See. http://forums.sohc4.net/index.php/topic,131817.msg1471876.html#msg1471876
« Last Edit: March 06, 2016, 09:39:27 PM by AshimotoK0 »
« Reply #2 on: March 07, 2016, 06:09:46 AM »
What engine number is it as there are too many bulletin pages to post
Offline RGP750
« Reply #3 on: March 07, 2016, 08:42:03 AM »
Thanks Ash
That is pretty informative, must have cost Honda o lot of money.
There is a bulletin in that link but it seems to be dead.
so Brian if you have anything it would be
good to see
engine no is 1016596
cheers Rich
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #4 on: March 07, 2016, 01:05:12 PM »
Thanks Ash
good to see
cheers Rich
Think James downloaded the entire information of that brilliant site I found with all of the Bulletins on it Rich.. We need to share it on here too. I think Trigger or Julie got a copy off James
it was here but link mentioned is dead now
http://www.sohc.co.uk/index.php/topic,9036.msg61908.html#msg61908
« Last Edit: March 07, 2016, 01:10:07 PM by AshimotoK0 »
« Reply #5 on: March 07, 2016, 07:17:08 PM »
I'll see if I can find a way of re-sharing these files. Bear with me. Rich - drop me an email and I'll reply with the files you need or ask Graham as well. Just putting the kids to bed ...
« Last Edit: March 07, 2016, 07:46:30 PM by AshimotoK0 »
« Reply #7 on: March 08, 2016, 07:21:24 AM »
You want bulletin No 29, saves me scanning it!!!
Offline RGP750
« Reply #8 on: March 08, 2016, 01:20:24 PM »
Hi Guys
Thanks for your help.
Bulletin is interesting thanks.
Hopefully sorted this weekend.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
