Author Topic: Exhaust Bracket Positioning Problem  (Read 1672 times)
Offline paulbaker1954
« on: March 07, 2016, 08:47:14 AM »
Just fitting my aftermarket CMSNL pipes and brackets and all not gooing fully to plan. >:( >:(
Not having had original pipes I am not sure of the correct bracket order on the foortrest bracket.
Considering the LHS pipes does the No 1exhaust  bracket go behind the footrest bracket or in front of it? Where does the No 2 bracket go iin relation to the peg , No 1 etc
Hopefully my description makes sense.
Looking frmo the outside I believe the correct order of metal is footrest, pillion bracket, No 1 bracket, No 2 Bracket, ie both exhaust brackets go behind the fottrest bracket.
If anyone has a pic showing the correct order that would be most helpful
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Chris400F
Re: Exhaust Bracket Positioning Problem
« Reply #1 on: March 07, 2016, 09:16:06 AM »
