Author Topic: Counter shaft oil seal  (Read 6349 times)
Offline TwiggsiiieS
« on: March 21, 2016, 03:03:05 PM »
Can anyone tell me if this seal can be replaced without splitting the crankcase, its the one behind the front chain sprocket.
The schematic seem to show a locating pin on the top. Seems like this could be common problem but I can't find any threads, so sorry if I've missed it and thanks in advance. Its a 1978 400f
Offline MCTID
Re: Counter shaft oil seal
« Reply #1 on: March 21, 2016, 03:16:51 PM »
Hi....check out the recent post from Roy Hall......I'm sure that he had a problem with a seal on his 350F, but managed to replace it without any drama.
Not sure if it's the same seal as yours.....but it might well be.
Good luck anyway.
Offline Chris400F
« Reply #2 on: March 21, 2016, 03:22:33 PM »
I was thinking about Roy's thread too (http://www.sohc.co.uk/index.php/topic,9636.0.html) but it was for a different seal.
Might be the same principle though, worth a read.
« Reply #3 on: March 21, 2016, 04:16:26 PM »
Proper location of the peg is vital to bearing life so you have to split the cases mate sorry
Offline TwiggsiiieS
« Reply #4 on: March 21, 2016, 09:36:39 PM »
Thanks all, have only just got the bike and want to ride it a bit( well alot) before I pull it to bits. Yes Royhalls thread is very smilar but different seal. I will re read the whole thread again. Dont know how to go back to it while replying but i remember someone mentioning "opening the crankcase a tadge" is this doable in situ?I think I will buy a seal just to what it looks like.
« Reply #5 on: March 22, 2016, 05:49:40 PM »
Cant split cases in situ, always worth freeing off cam chain tensioner when apart
Offline TwiggsiiieS
« Reply #6 on: March 22, 2016, 10:13:29 PM »
Yep makes sense you want to reseal everything, it just gonna have to leak for the season and will sort next winter.
There's about four drips when if first stops. I can live with that.
I have a sinking feeling that the end of the counter shaft may be damaged, will have to wait and see!
Thanks,
Steve
