Author Topic: K6/K7 Front Forks - F1?  (Read 7425 times)
Offline Coppertop1234
  • As long as the wife is happy
« on: April 05, 2016, 10:13:15 AM »
Looking at our options and it would seem that F1 forks are limited in availability .We presently have F2 forks fitted but my question is in compatibility of various models.
I know the F1 fork legs are longer than the K6, but could I fit the f2 chromed fork legs into K6 or K7 bottom units.
or are they similar but not compatible.?
Any options for consideration the f2 fork legs has no fittings on the bottom units for the F1 mudguards
We can keep what we have for present but just so I know what to watch out for when I find them for sale
I Love Tinkering with Old Classics
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1962 Triumph 650 Bonneville
1972 Norton Commando
1978 Honda CB400/4
1976 CB750F1
1976 Suzuki GT750 Kettle
1978 Honda CB 750 F1
Married Life No Bikes for a while then
1975 CB Honda 400/4 Restoration
1976 Kawasaki Z650   Restoration
2002 Suzuki GSX1400
1976 Honda cb750F1  Restoration
1978 Honda cb750 F1 Restoration
1977 CB 250 Dream    Restoration
1977 CB400/4  - The last one - Restoration
Re: K6/K7 Front Forks - F1?
« Reply #1 on: April 05, 2016, 01:29:42 PM »
You will find that K6 forks are 341 and K7 are 393, so are different.
I would just keep my eye out for a set of F1's, even if they are pitted and get them re-chromed ;)
« Reply #2 on: April 05, 2016, 04:43:00 PM »
Hi Trigger
I was hoping to use the chromed legs from the F2 forks and fit them into F1/K6/K7 Bottom alloy legs (if I can find any)
If its just the length of the chromed tubes thats different it shouldn't be a problem using a F1/K6/K7 bottom unless they just ain't compatable.
I don't want to be spending daft money and ending up with a mismatch that just won't fit - like you say ideally  just find a bog standard set of F1 forks - problem would be solved
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #3 on: April 05, 2016, 05:08:46 PM »
I could be wrong but i thought the F2 had different seal sizes
« Reply #4 on: April 05, 2016, 06:18:28 PM »
Think I have some K7 bottoms .. well got the whole legs but stanchions are deffo sha**ed
« Reply #5 on: April 06, 2016, 06:34:53 AM »
Hi Ash - could this be a resolve to my fork issue
would my F2 stanchions drop into the K7 bottoms?
If so let me know what you want for the bottoms and I don't think your too far from me to collect
Keith Snr
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #6 on: April 06, 2016, 08:22:05 AM »
Keith Snr
Will have to dig them out of the shed Keith... unsure on condition.or what will fit them stanchion wise .I was going to bung em on the worlds most famous auction site for a tenner.
« Reply #7 on: April 06, 2016, 10:32:06 AM »
for a tenner I will give them a blast
Let me know when you have found em out and PM me with where you are
Keith Snr
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #8 on: April 07, 2016, 09:16:19 PM »
Keith Snr
Stanchions & Springs same part no. CB750K7 and F2. STANCHION:  51410393003 , SPRING 51401393000
Dug them (literally) out of the shed & look a bit crusty. Will take 'em to work and bead blast the alloy sliders. Stanchions are pitted but would definitely rechrome & not bent.
I am in Willerby East Yorks just outside of Hull just off the A164 between Hull & Beverley.
« Last Edit: April 07, 2016, 09:21:43 PM by AshimotoK0 »
« Reply #9 on: April 08, 2016, 07:38:17 AM »
Excellent stuff Ash
When your ready I will collect or ask Keith Jnr to collect if thats ok
Keith Snr
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #10 on: April 09, 2016, 07:29:12 PM »
Forks blasted OK but noticed on one the bottom studs were sheared off plus a bit of the caliper adjuster screw was rock solid seized into the alloy. MIG welded a nut to the studs and they came out with a bit of gentle persuasion. Also welded up a rear shock compressor tool at the same time.
« Reply #11 on: April 11, 2016, 07:12:02 AM »
Natty idea for spring compressor Ash
Fork Legs look fine cheers for all the prep work.
If you will send me you phone number we can arrange to meet and collect
Keith Snr
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #12 on: April 11, 2016, 07:24:34 AM »
Keith Snr
No worries ... I didn't want you to come and pick up and find them fooked 'cos studs were stuck solid and I was welding things anyway. I would leave the studs in the other one well alone !!
its 07515121226
