Author Topic: Piston ring end gap  (Read 5778 times)
Offline stevush
Piston ring end gap
« on: April 19, 2016, 11:44:04 AM »
Can anyone enlighten me as to the end gaps for each of the three piston rings in the bore please ?
Its a new rebore +.5, new pistons and rings. I've looked at the top ring in the bore and it looks to be about 9thou, how does that sound ?
I'd assume the gap should be the same for the second ring, I think the oil control ring should be a little bigger ?
Steve
Offline Chris400F
Re: Piston ring end gap
« Reply #1 on: April 19, 2016, 03:26:29 PM »
Found these figures in the Honda Shop Manual.
9 thou is bang in the middle of the range, as you say the oil ring gap should be slightly bigger.
Interestingly for the 350F the gap is given as 0.1 - 0.3mm for all three rings.
« Last Edit: April 19, 2016, 03:48:00 PM by Chris400F »
Offline stevush
« Reply #2 on: April 19, 2016, 05:32:47 PM »
Thanks Chris,
I thought that there may be a difference after a rebore but in hindsight I don't think it matters.
Steve
Offline Chris400F
« Reply #3 on: April 19, 2016, 09:23:44 PM »
Thinking about it (always a dangerous thing to do ....) a rebore to +0.5mm is less than a 1% increase in bore diameter so I wouldn't expect any change in tolerances.
