Author Topic: Carb Removal definitely the easy way - at least this is my view  (Read 5837 times)
Offline paulbaker1954
This may have been posted before but I really struggled with getting my carbs on and off, after some experimentation I seem to have mastered the easiest way. I can have the carbs off in 15 minutes and back on in 20.
Here is how it goes..........
1) Remove the air filter and airbox, remove the throttle cables, remove tank.
2) Undo the clamps on the engine side and the airbox side and remove the airbox side clamps as it just saves them from getting bent and in the way generally. You can slide them around and off pretty easily.
3) Now push the airbox to carb rubbers back in to the airbox a bit using fingers/blunt screwdriver whatever. You dont need to push them right through just back about an inch util they are off the lip that holds them in the right location relative to tteh carbs.
4) Now you have gained a bit of extra space and the carbs can be pulled off the intake and waggled free pretty easily.
5) To get it all back together slide the carbs back i. From the righ seems easier for some odd reason.
6) Now -  for the middle two rubbers put your hand through the hole in the back of the airbox and push them back out to the right position. Bit fiddly but a combination of pushing and rotating works pretty easily
7) For the two outer rubbers you can pull these through from the engine side easily to their right position
8) Put clamps back on and tighten, refit cables and tank and ride off in to the sunse
9) You are now a carb jeddi  :) :) :)
Two things that help
A) A spray of silicone lubricant or similar helpe with the pulling/pushing.
B) If the rubbers are old and brittle you are going to break them.
I hope this is of some help to others - I really struggled until I got this technique and it's just so easy.
I guess this only fails if you have such giant hands you cant get them inside the airbox but they'd be some mighty big hands I think.
« Last Edit: April 19, 2016, 04:30:30 PM by paulbaker1954 »
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Carb Removal definitely the easy way - at least this is my view
« Reply #1 on: April 19, 2016, 06:06:51 PM »
All good advice....warm the rubbers up with a hairdryer.
Offline Aly-b
« Reply #2 on: April 19, 2016, 06:36:37 PM »
Hints and tips are always welcome. :)
« Reply #3 on: April 19, 2016, 07:54:25 PM »
 I find loosly mounting the top of airbox/plenium chamber help to hold it up out of the way,
the reason the Carbs are easier to fit from the R/H side,is the clutch cable (500) gets in the way
