Author Topic: Indicators not flashing  (Read 1704 times)
Offline yozzer74
« on: May 20, 2016, 07:59:37 PM »
I'm on with making my wiring harness .I've wired indicators up with new led relay but they won't flash .they just stay on solid.any ideas
Offline MarkCR750
Re: Indicators not flashing
« Reply #1 on: May 20, 2016, 08:17:01 PM »
Are you sure that the flasher unit works, do you have another one you can slave in?
Suzuki GT250A (Nostalgia)
1977 K7 CR750 (lookalike, what of I’m not sure)
Ducati 900SS (Soul & Speed)
Ducati M900 Monster (Handling & character)
Thruxton 1200 (suits me)
James Captain 197 (pure adrenaline, i.e. no brakes!)
Sir J.Stewart.
Offline yozzer74
« Reply #2 on: May 20, 2016, 10:34:46 PM »
It is a new one but going to get another to try
« Reply #3 on: May 21, 2016, 06:02:32 AM »
Either the load is wrong or the voltage is low, frequently indicators only flash with the engine running to charge the battery
Offline yozzer74
« Reply #4 on: May 21, 2016, 06:24:43 AM »
Cheers Bryan
Offline yozzer74
« Reply #5 on: May 21, 2016, 06:32:34 AM »
How do I know if the load is wrong
Offline hairygit
« Reply #6 on: May 21, 2016, 07:43:10 AM »
I think Bryan is referring to the stock flasher unit, which needs the correct wattage bulbs to activate properly. Most led rated electronic ones it makes no odds, the load can generally be anything from zero to 250 watts. Check you have wired the flasher in correctly, often the connections will be different to stock. If that doesn't work, you've got a duff flasher!
Sent from my D2303 using Tapatalk
Offline yozzer74
« Reply #7 on: May 21, 2016, 12:12:54 PM »
This is my relay does it matter which wire goes on which terminal .there are no markings on either one .I had one wire from switch & one from power [ Guests cannot view attachments ]
Offline mike the bike
« Reply #8 on: May 21, 2016, 04:14:34 PM »
Sounds like there's only 2 wires on it.  The obvious thing to do is to swap the wires and see if it works.
Offline yozzer74
« Reply #9 on: May 21, 2016, 05:58:54 PM »
Done that didn't work
Offline Coppertop1234
« Reply #10 on: May 21, 2016, 06:31:47 PM »
Try tapping the flasher unit - it may just be stuck on the terminals inside
I Love Tinkering with Old Classics
Offline ginger_jim
  • Anyone for a Guinness?
« Reply #11 on: May 22, 2016, 04:55:53 PM »
Are you using the original indicator switch?  I had exactly the same problem, tried all sorts and it turned out to be that the switch arm was travelling too far across the contact bar because the mechanism was worn.  I restricted the travel by spacing out the housing and the indicators have been perfect ever since.  I might add that the switch didnt feel particularly loose or wobbly.  Might be worth a try, but fiddly taking the switch apart...... ;)
Offline yozzer74
« Reply #12 on: May 22, 2016, 05:55:55 PM »
No ginger it's a new switch  :(
