Author Topic: Bike won't start - help!  (Read 11878 times)
Offline paulbaker1954
Re: Bike won't start - help!
« Reply #60 on: June 10, 2016, 11:31:10 PM »
Have you synced carbs recently. I synced mine a while ago, finished job and she wouldn't start because stupidly I had left the vacuum connection screws on the bench. Put them back in and problem solved
Sound like you may have a vacuum leak
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Rob.b (Rob Birkett - RIP)
« Reply #61 on: June 11, 2016, 10:02:57 AM »
Ok it's time for me to add my two penneth, I hope you don't mind I don't think I've got anything amazing to say but I have been reading these threads with interest and even thinking about them in the small hours so it's time for me to contribute.
I want to suggest that it is not feel related and the reason I think this is because the bike began to be hard to start and then wouldn't start at all. Since then you have done lots of checks and fixes including putting fresh petrol in it even easy start still nothing. Then one day with a new fuel supply made it start and it ran fine then it stopped and wouldn't start again just doesn't sound sensible that it's fuel given that we checked everything in the fuel line.
I am going to go back to possible electrical problems; you say it sparks. Is it a nice big fat blue spark or a whmpy little orange one, also is it sparking reliably does it always spark when it should, has the timing had chance to slip and then get in the right orientation and then slip off again is the ignition switch working properly is the Killswitch working properly all of the taking the fuel tank on and off are you disturbing a wire aound the coils?
Two nights ago starting at 11pn I set off from home on my Cb500 and did 270miles down into mid Wales then home up the A49 it was brilliant,  anyway I started to think about your bike and I began to think about electric issues because it's intermittent and the fuel system has had a very thorough going over.
Hope this is of some help. I'm desperate to find out what's going on with your bike.
Rob
Offline MCTID
« Reply #62 on: June 11, 2016, 01:02:37 PM »
I reckon Chris400F has the solution........try running it without the Fuel Cap to check whether the vent hole is blocked or not. You didn't say whether you had checked it but when you ran it from a Auxiliary Fuel tank it was OK.
I had a Lambretta years ago (I know but I was only 16) that ran OK for a while then cut out - after checking there was fuel in the tank (under the seat) it ran OK again for a while. Same again.........eventually discovered that it was my Over trousers which I kept stored under the seat which was blocking the vent hole.
Just try it.
Offline JustcallmeMrT
« Reply #63 on: June 11, 2016, 08:16:08 PM »
I had hopes this would be the issue as I headed to the shed this morning, but unfortunately not.  All the vacuum connections were nice and tight.
Sent from my SM-N9005 using Tapatalk
« Reply #64 on: June 11, 2016, 08:42:26 PM »
Just try it.
I just went out and checked - no difference with the cap on or off.
Offline tom400f
« Reply #65 on: June 11, 2016, 08:59:50 PM »
How about those of us in range all meet up at Mr T's for a group effort? I'm in.
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
« Reply #66 on: June 11, 2016, 09:19:33 PM »
I'd be very glad for the help!
« Reply #67 on: June 12, 2016, 12:39:26 PM »
I'd help with looking at it as getting a few heads together could possibly grasp something missing in our more remote efforts.
Got a few tools like decent compression tester, meter, strobe etc that may assist with a more comprehensive look through the bike.
Let us know a time, etc to see if I can match up.
Offline Seabeowner
« Reply #68 on: June 12, 2016, 05:14:39 PM »
Mr T, Sent you my no earlier. Did you get it? If you are working days, can come Tuesday eve.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
« Reply #69 on: June 12, 2016, 05:41:18 PM »
Well fellas, I work days so any evening after 6 would work for me, or potentially next Sunday, if the mechanic I've contacted hasn't picked up the bike by then.  Let me know how things work for you all.
Offline tom400f
« Reply #70 on: June 13, 2016, 10:33:20 AM »
It's raining all week :(
Sat/Sun, possibly. Might be dry then... :\
1978 CB400F2 Yellow
1995 VFR750FS Red
« Reply #71 on: June 15, 2016, 12:30:01 PM »
Finally gave up and had the bike in to a mechanic.  Turns out it is the coils.  When I checked them with a multimeter it seemed fine, but they swapped in a new set and it runs fine again.  I can't believe my Dyna ignition and dyna coils have both fried withing a few weeks.  I'm going to make a warranty claim.  Has anyone else had these kind of problems?
Offline mike the bike
« Reply #72 on: June 15, 2016, 12:31:58 PM »
I've got Dyna coils and ignition on mine.  Perhaps you've got the wrong resistance.
« Reply #73 on: June 15, 2016, 12:37:23 PM »
5 ohm?
« Reply #74 on: June 15, 2016, 12:39:38 PM »
I've got coils and ignition receiving switched power via the motogadget m-unit auxiliary output, and the blue and yellow wires going from the ignition to the coils.  The coils are 5 ohms.
