Author Topic: CB550 Dowel Pin Location  (Read 1027 times)
Offline ashtonjason
« on: July 21, 2016, 11:32:52 AM »
Hi all, I am new to this and need a little help.  I am currently rebuilding a 1977 cb550 k3 and turning it into a cafe racer.  I have currently got most of the engine back from vapour blasting and have been doing a dry fit of all the internals to make sure there are no spare parts left over before I glue up the case.
Well I have two dowel pins which I can not find a home for.  They are solid and measure 10mm x 16mm.  I have two already located in the engine case towards the carb side of the crank, but I can not find where the other two go.
Any help would be much appreciated.  Any further information just let me know
Offline JustcallmeMrT
Re: CB550 Dowel Pin Location
« Reply #1 on: July 21, 2016, 11:48:10 AM »
Are they the ones from the top of the head to locate the cam cover?
Sent from my SM-N9005 using Tapatalk
Offline ashtonjason
« Reply #2 on: July 21, 2016, 11:58:23 AM »
You are fantastic, yes they are.  For some reason I thought bolts went through, but wrong there.  This is great news I can get on with joining the case together.
Once again, thanks,
« Reply #3 on: July 21, 2016, 01:14:15 PM »
No worries,  good luck with the build!
