Author Topic: Not one for the 'purists' ....carb clean.  (Read 1089 times)
« on: August 02, 2016, 08:24:15 AM »
In another post I described the horrors inside of my CB400/4 carbs, after standing with petrol in (convinced I had drained them  :-[), since probably before JamesH was born ( well 1986)
Anyway after pressing out the stubborn float pins (see tool picture below) etc and even bunging in  a big ultrasonic cleaner @ 70°C with the correct fluid in all afternoon, they still looked grotty inside. So I totally sealed everything ( wrapped the outside with industrial cling film and 'self amalgamating' tape, sealed the main-jet pillar  and float valve with adhesive lined heatshrink, bunged tapered copper rivets into the rear casting holes etc and bead blasted them with 0/50 glass beads on a really low pressure, then blasted with compressed air and now back in the ultrasonic again for a thorough clean elsewhere. I am convinced this will be OK but not one for the purists.
I was lucky as the main jet pillar was not badly corroded and 'moth-eaten'. I reckon, along with broken float posts that this is the death sentence of many Honda carbs, particularly with water ingress too (like a lot of import bikes suffer from).
« Last Edit: August 02, 2016, 08:47:38 AM by AshimotoK0 »
Re: Not one for the 'purists' ....carb clean.
« Reply #1 on: August 02, 2016, 08:39:14 AM »
That's looking really clean Ash. I did mine yesterday, from my CB550. They were painted black and not looking good at all. I soaked them in diesel for a day, put them in the soda blaster, washed them off with fairy, a quick blow with the airline and they came out like this. I'm really pleased with them.
« Reply #2 on: August 02, 2016, 10:51:34 AM »
Nothing wrong with this approach in my opinion. Critical part is making sure the internal fuel / aire ways are properly sealed like Ash has done.
Then another good ultrasonic clean in a hot bath and you're sorted.
Nice work both of you..
James.
« Reply #3 on: August 02, 2016, 11:23:48 AM »
Great work Julie... wish my 'girls' were as practical as you !
« Reply #4 on: August 02, 2016, 01:29:14 PM »
Ha. The practical aspect of it was that I was cooking a roast dinner at the same time  ;D ;D ;D
