when you say no resistance,do you mean it come to the bar with nothing happening? or its just very spongy,or soft.
you could try a reverse purge,take the pads out,pump the brake untill the piston is almost out,then carefully use a G clamp to
push the piston back,it may flush any air out of the master cylinder,
good luck,and be careful of the brake fluid,it kills paintwork
