Whats the recommendations for replacement batteries....... Lets assume that money is not the deciding factor, and were after performance and longevity......... The battery will be in a cold garage over winter, on the bike with an optimiser permanently fitted. The optimiser is rated for all types of battery......... Should I go for Lead Acid, Glass Mat, Gel, or Lithium?
Quote from: royhall on December 16, 2016, 05:59:18 PMWhats the recommendations for replacement batteries....... Lets assume that money is not the deciding factor, and were after performance and longevity......... The battery will be in a cold garage over winter, on the bike with an optimiser permanently fitted. The optimiser is rated for all types of battery......... Should I go for Lead Acid, Glass Mat, Gel, or Lithium?Do not use acid if you value your exhaust system
