Author Topic: Cold start  (Read 1850 times)
Offline rusty nuts
  • Bikes Cb 750 matchless g3l .times 2 1941 and 1949
Cold start
« on: January 03, 2017, 06:03:49 PM »
My 1975 cb 750 when starting from cold only runs on three cylinders then after about a minute runs on four and is fine any ideas anybody.
Offline Jore
Re: Cold start
« Reply #1 on: January 03, 2017, 06:25:30 PM »
Is it always the same cylinder?
Offline rusty nuts
Re: Cold start
« Reply #2 on: January 03, 2017, 06:30:25 PM »
Yes number three .
Offline Jore
Re: Cold start
« Reply #3 on: January 03, 2017, 06:57:03 PM »
It might be a sticking float valve that frees itself with the vibration of the other cylinders running.
Re: Cold start
« Reply #4 on: January 03, 2017, 07:48:50 PM »
Another Newbie from Lincolnshire, welcome to the forum.
Offline rusty nuts
Re: Cold start
« Reply #5 on: January 03, 2017, 07:57:26 PM »
Yes a newbie from the posh part of lincolnshire ?
Re: Cold start
« Reply #6 on: January 03, 2017, 08:14:41 PM »
   that must be with the hills and valleys !!
 welcome to sohc fun palace !!
Re: Cold start
« Reply #7 on: January 03, 2017, 08:27:59 PM »
Is there a posh part? Woodhall Spa would be the 'poshest' I suppose. Ok if your thing is chasing  white balls around a field  ;D ;D ;D Or is it Stamford?
« Last Edit: January 03, 2017, 08:51:48 PM by Nurse Julie »
Offline rusty nuts
Re: Cold start
« Reply #8 on: January 03, 2017, 08:59:48 PM »
Re: Cold start
« Reply #9 on: January 03, 2017, 09:03:44 PM »
;D ;D ;D
Re: Cold start
« Reply #10 on: January 03, 2017, 09:05:17 PM »
Yes John
Re: Cold start
« Reply #11 on: January 03, 2017, 09:49:19 PM »
Welcome to the forum.
Don't known what you've checked so far so some things to verify I'd do; swap plug leads 2 with 3 if they'll reach to reasonably eliminate the HT section of number three.  Start it in the dark and look to check for HT leads tracking to earth when you first start it.
Check to see the choke flap for no 3 is intact and going to position correctly.
Suspect the idle circuit on no3 if you're not certain it's clean and operating correctly. Try backing idle screw out on no 3 while it's running to see if it responds.
Swap the plugs on 3 and 4 to see if problem transfers.
Are the compressions equal for all four cylinders.
Offline rusty nuts
Re: Cold start
« Reply #12 on: January 03, 2017, 10:01:42 PM »
Thanks will try that.
Offline shifter
Re: Cold start
« Reply #13 on: January 04, 2017, 09:55:14 AM »
Yes Rusty ,Now that is the nice part of Lincs ,
" RIDDEN NOT HIDDEN"
 Moto morini 250 2c
Cb200
S90
Greebo
  • Guest
Re: Cold start
« Reply #14 on: January 05, 2017, 08:45:09 AM »
1st thing I would try is another spark plug in No 3 either swap one from another cylinder or a brand new one
