Author Topic: Rear sprocket carrier bearing  (Read 565 times)
Offline Niko
« on: February 20, 2017, 05:24:55 PM »
Hi....could someone point me in the direction of the correct bearing for the sprocket carrier please. I believe my carrier to be the early type. 76 USA f1
Thanks in advance
Offline Niko
Re: Rear sprocket carrier bearing
« Reply #1 on: February 20, 2017, 05:26:15 PM »
This is the carrier
Offline Niko
« Reply #2 on: February 20, 2017, 05:37:16 PM »
Are there two wheel bearings plus a sprocket carrier bearing.....or just two bearings?
« Reply #3 on: February 20, 2017, 07:26:49 PM »
Should be only 2, a 6304 and a 6305. It will give the number on the bearings
Offline Niko
« Reply #4 on: February 20, 2017, 08:48:11 PM »
Thanks Trigger.....was going nuts for a bit ....now it makes sense. Cheers
