Author Topic: PD46 carb question .... where does this bit go..  (Read 646 times)
Offline Ashdowner
« on: March 27, 2017, 08:00:55 PM »
Help please. I'm just putting the carbs back together in accordance with Brian Barnes' excellent guide, and I've got carbs 1 & 2 mounted.. I thought I'd taken photos from every conceivable angle to leave nothing unrecorded, but I have a piece of plastic that I can't find a home for and which doesn't appear in Brian's work or on any exploded view that I can find. Judging by the diameter of the hole, it goes somewhere on the throttle shaft, so before I go any further could someone please tell me exactly where and facing which way?
CB550K3, CB550K1, Yamaha Midnight Star, and CA77 in 2473 pieces (at the last count)
Re: PD46 carb question .... where does this bit go..
« Reply #1 on: March 28, 2017, 07:42:41 AM »
Something to do with the choke mech spring?
Offline Seabeowner
« Reply #2 on: March 28, 2017, 09:37:40 AM »
Ashdowner it goes on the throttle shaft on carb 2 (the one with the non adjustable slide). Hope you can see it in the pic, it sits between the brass that is screwed to the throttle shaft and barb body as a sort of bearing surface. (horrible job)
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline Ashdowner
« Reply #3 on: March 28, 2017, 06:20:29 PM »
Thanks Seabeowner. I actually finally found it on one of my photos but thanks for your reply. Got the carbs together apart from everything in the bowls. First set of shiny clean carbs I've ever had
