Author Topic: Oil pipe hose  (Read 828 times)
Online philward
Oil pipe hose
« on: March 31, 2017, 11:00:11 PM »
I've got to make up a set of oil lines for the CR750 project - I'm using an early cbr600 oil cooler to the standard CB750 engine fittings.
I'd like to make them up myself if possibe but if not I will have them made up.
Can anybody make any recommendations for suppliers?
Re: Oil pipe hose
« Reply #1 on: April 01, 2017, 09:07:53 AM »
Anyone in your area that makes up hydraulic lines should be able to make them up for you.
Offline Mag1
Re: Oil pipe hose
« Reply #2 on: April 01, 2017, 11:00:03 AM »
I brought a set from wemoto, HEL oil lines and fittings, will report later if they hold up. But they are wire braded and mini screw worm fittings , see link below. They are a bugger to fit and line up, very stiff to install, and the fittings are rubbish and don't fully tighten as the screws just keep turning. But they should hold ok for now and I will change them in the winter for better fitting oil lines. No leaks yet, but have not had the engine running yet. But when researching the same as you, found out that cyclexchange in us sells the hose by the ft which is what I may order later and new fittings. Or if I can find some same diameter pipe work will make up set myself.
Honda CB750K7 1977
Yamaha XS750e 1977
Vespa 100 (being restored)
Offline Mag1
Re: Oil pipe hose
« Reply #3 on: April 01, 2017, 11:01:05 AM »
http://www.wemoto.com/parts/picture/hz-oillinecb750/ , now with link
Honda CB750K7 1977
Yamaha XS750e 1977
Online philward
Re: Oil pipe hose
« Reply #4 on: April 01, 2017, 12:40:14 PM »
Thanks the reply - the lines are not standard due to CR750 rep oil tank and oil cooler so will need non standard lines.
I have just realised that due to the inclusion of the oil cooler, I need extra lines/fittings so I'm short of the oil pipe in the picture. Has anyone got one to sell - it can be knacked as long as fittingsare serviceable
Re: Oil pipe hose
« Reply #5 on: April 01, 2017, 06:00:50 PM »
I will have one somewhere, just need to find were I put all the oil lines.
Online philward
Re: Oil pipe hose
« Reply #6 on: April 01, 2017, 06:25:42 PM »
Cheers Graham - only need the end fittings
Re: Oil pipe hose
« Reply #7 on: April 01, 2017, 06:50:55 PM »
Sent you a whatsapp mate.
Online philward
Re: Oil pipe hose
« Reply #8 on: April 01, 2017, 07:17:31 PM »
Pipes sorted - cheers Graham
Re: Oil pipe hose
« Reply #9 on: April 01, 2017, 08:44:22 PM »
cheers for the forum donation  :)
