Author Topic: CB750 Oil Pipe Nut sealing  (Read 1103 times)
Offline philward
« on: April 19, 2017, 06:14:27 PM »
As I've built my CR750 from bits, my oil pipes have been one of the bits I've sourced. I've butchered the fittings to make new oil lines up for the CR oil tank and oil cooler but the nut fittings that fits to the underside of the oil tank (same as standard oil tank) doesn't have any sort of seal within the nut. I've checked on the CSML schematics and there's no separate seal listed.
Save me stripping my standard K2 bikes oil lines to find out what seals are used, can anybody tell me what seal is used - o ring, flat rubber seal or fibre washer?
Offline steff750
  • THE POWER OF DREAMS
Re: CB750 Oil Pipe Nut sealing
« Reply #1 on: April 19, 2017, 07:16:21 PM »
 :) originally they came with soft white metal washers from honda.there is no part number for them so i assume they only came with new oil pipes
but im sure copper is ok aswell as there is not a lot of pressure in the actual oil tank
 britt bikes use fibre washers but that still dont stop em leaking lol
Offline philward
« Reply #2 on: April 19, 2017, 07:30:00 PM »
thanks Steph - I'll get on ebay and get some sourced
« Reply #3 on: April 20, 2017, 09:50:35 AM »
I also was surprised to find metal washers in the fittings on my 750F1 oil lines as they were not listed on the parts book, now I know that it wasn't a production line bodge up.
Offline martin_uk
« Reply #4 on: May 07, 2017, 04:06:29 PM »
I used aluminium washers on mine
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline onethumb
« Reply #5 on: May 13, 2017, 08:58:35 PM »
I had the same issue and was recommended dowty washers. They look the biz.
"20 in a 40 is not safe driving"
