Author Topic: Spongy front breaks  (Read 875 times)
  • Colonial_clive
Spongy front breaks
« on: April 23, 2017, 03:28:57 PM »
Here we go people's, I have put twin disks on the bike with rebuilt caliper said and resavoir, new SS hoses and washers! I have bleed the system from top to bottom and vacuum bleed the calipers, also left over night with lever tied to handle! I can without any effort STILL touch the hanle bar with leaver.
 Anyone got ideas how I can go from soft and spongey to hard?
Thanks Clive
Offline hairygit
Re: Spongy front breaks
« Reply #1 on: April 23, 2017, 03:45:07 PM »
Try adjusting the caliper's free play.
« Reply #2 on: April 23, 2017, 04:02:57 PM »
when I fitted a R/H disc,I found the pads were not square on the disc,
 you need to align the caliper and disc as accuratly as possible,
as little as 1 mm difference between top and bottom,also front and back,will give a spongy lever
  • Colonial_clive
« Reply #3 on: April 23, 2017, 04:11:41 PM »
Hairygit locked up and backed off 1/2 turn.
Johnwelby both running true as far as I can see.
Offline hairygit
« Reply #4 on: April 23, 2017, 04:31:29 PM »
That actually sounds too much! Should be 6 thou clearance, which is 0.152mm, each half turn of the adjuster screw (m6x1) is 0.500mm, WAY too much!
  • Colonial_clive
« Reply #5 on: April 23, 2017, 05:56:52 PM »
Problem solved (I hope) just pulled callipers apart and one is weeping, so much for non OEM seal and piston new OEM one on way hope this fixes it!
Will post update when fixed.
Offline hairygit
« Reply #6 on: April 23, 2017, 06:02:52 PM »
Lesson to be learned there, NEVER buy anything but OE seals for brakes, your life depends on them! When you have fitted the replacements, adjust the calipers properly, and all should be well. ;D
« Reply #7 on: April 23, 2017, 06:13:08 PM »
Did you replace the master with one from a twin disc system eg goldwing?
