Author Topic: Rear wheel Ovalised?  (Read 961 times)
Offline El__burro
« on: May 03, 2017, 04:27:12 PM »
Good day...
Issue is felt mainly when rear brake is applied.
I remember cleaning the hub and brshoes.
Anyone with opinions about this.
el__burro
Sent from my SM-G935F using Tapatalk
« Last Edit: August 01, 2018, 12:01:32 AM by El__burro »
Offline hairygit
Re: Rear wheel Ovalised?
« Reply #1 on: May 03, 2017, 04:44:48 PM »
Brake drum distorted or cracked. Will require skimming in a large lathe if distorted, or replacing if cracked. :'(
Offline El__burro
« Reply #2 on: May 03, 2017, 06:54:07 PM »
So not the wheel, the drum?
Is $kimming cheaper than a new drum..?
Any skimmer in London?
What a blow!
el__burro
« Last Edit: May 03, 2017, 07:08:27 PM by El__burro »
Offline matthewmosse
« Reply #3 on: May 03, 2017, 07:43:20 PM »
There is a guy in Huddersfild who is at least both cheap and very highly reccomended by all accounts. Look over in the cb550 section as his details have just been posted up there.
Offline El__burro
« Reply #4 on: May 03, 2017, 10:58:04 PM »
..thanks, Huddersfield looks a bit far from London, I'll have to send him the rear tyre?
That would add a lot to the final cost.
el__burro
Offline El__burro
« Reply #5 on: May 06, 2017, 04:57:38 PM »
After giving it a good clean, it was slightly better.
thanks
« Last Edit: August 01, 2018, 12:02:27 AM by El__burro »
Offline hairygit
« Reply #6 on: May 06, 2017, 08:02:04 PM »
Hate to put a damper on things, but there is NO WAY on this earth I would ride that having seen those cracks! I'd be on the lookout for a good used hub or wheel, or getting a new liner fitted before riding it again. (Sorry :'()
Offline kevski
« Reply #7 on: May 06, 2017, 08:19:46 PM »
Now you have seen it, that makes it a liability, if an MOT tester see that now they are duty bound to declare it unfit for the road, you have also now published it a public domain, if you continue to use it in that state you become a liability.
« Reply #8 on: May 06, 2017, 11:55:44 PM »
There is no way that that will skim, its either a different wheel or a reline. Doubt you will find any one in London with a big enough lathe to do the assembled wheel, I have visited Paul in Huddersfield and he does not need the work as a business but does it "Because he can"
Don't forget when you signed up for your insurance you say you will keep it in good repair and roadworthy, sorry that don't fit in either category no matter what the MOT says
Offline El__burro
« Reply #9 on: May 07, 2017, 02:52:56 AM »
Thanks, i was happy to pass the MOT so I can get the bike registration complete. I am quite worried about it all, i could barely feel the problem.
el__burro
« Last Edit: August 01, 2018, 12:02:58 AM by El__burro »
Offline hairygit
« Reply #10 on: May 07, 2017, 07:07:50 AM »
They would remove the old drum lining, (the iron bit the brake shoes contact which is cracked) and force fit or shrink fit a replacement, then skim it to new spec.  The easiest thing would be to find a decent used wheel and fit that to get on the road, then get the damaged one relined as a spare.
Offline MarkCR750
« Reply #11 on: May 07, 2017, 03:21:59 PM »
Try D&K breakers for a replacement wheel, or eBay maybe.
Suzuki GT250A (Nostalgia)
1977 K7 CR750 (lookalike, what of I’m not sure)
Ducati 900SS (Soul & Speed)
Ducati M900 Monster (Handling & character)
Thruxton 1200 (suits me)
James Captain 197 (pure adrenaline, i.e. no brakes!)
Sir J.Stewart.
