Author Topic: Fuel tap leaking  (Read 1110 times)
Offline Niko
Fuel tap leaking
« on: May 18, 2017, 08:01:33 PM »
Hi...mine is a 20mm thread job. With two outlets
Inside is a little nylon cone....
How do I stop it leaking....or how do I replace.
It's driving me nuts and wrecking my floor.
My house smells like a bp garage
Offline kevski
Re: Fuel tap leaking
« Reply #1 on: May 19, 2017, 07:20:30 AM »
Buy a new one, or don't put petrol in it.
« Reply #2 on: May 19, 2017, 07:35:36 AM »
;D ;D ;D ;D ;D ;D ;D
« Reply #3 on: May 19, 2017, 07:44:47 AM »
For the 750F1 which uses a similar design of tap, albeit with a single outlet, Honda do a repair kit, which has a new nylon mesh cone and the large rubber washer that seals the joint between the tap and tank. The washer is sadly not available as a separate item, only in the kit, which is not particularly cheap.
Offline Niko
« Reply #4 on: May 21, 2017, 10:15:38 AM »
Do you have a link please...
Sent from my SM-G935F using Tapatalk
Offline Niko
« Reply #5 on: May 21, 2017, 10:16:26 AM »
....tried not putting petrol in...but it's a bugger to start...lol
« Reply #6 on: May 21, 2017, 10:21:24 AM »
« Reply #7 on: May 21, 2017, 01:28:37 PM »
Are you on commission from Sliver, Hairy ;)
« Reply #8 on: May 21, 2017, 02:07:40 PM »
  No Trig, unlike you, I have no issues buying from him, He has invested a lot of money in getting replacement parts made (ie  750F1 caliper bodies) that are otherwise unobtainable and would keep an otherwise good bike off the road!
« Last Edit: May 21, 2017, 02:10:21 PM by hairygit »
Offline Niko
« Reply #9 on: May 21, 2017, 06:01:10 PM »
Cheers....i think the cone is worn
Offline Niko
« Reply #10 on: June 05, 2017, 07:30:57 PM »
Got one today from d and k....17 quid......and it doesn't leak!
