Max arse tolerance on the wooden 400f seat was an hour when I was young and supple !
If you only bench-synced the carbs, it's probably time to do an actual vacuum sync.Weird idle definitely points to a poor synchronisation.
I have got new aluminum sealing washers in place and I'm sure they are not leaking as only idles high when hot.
Quote from: Nurse Julie on May 24, 2017, 08:08:15 PMI have got new aluminum sealing washers in place and I'm sure they are not leaking as only idles high when hot.That's indicative of air leaks.
