Author Topic: Hopelessly unreliable these CB750's  (Read 3159 times)
Offline MarkCR750
Re: Hopelessly unreliable these CB750's
« Reply #15 on: August 06, 2017, 04:36:42 PM »
Emily Ratajkowski is that her that use to play in Coronation Street ?.. :o thought you had better taste Mark. stick with the MV... ;D
She'd be more reliable, and probably "Go" better than anything shitalian!
Thought I'd flush you out with the Italian bit HG 😄
Suzuki GT250A (Nostalgia)
1977 K7 CR750 (lookalike, what of I’m not sure)
Ducati 900SS (Soul & Speed)
Ducati M900 Monster (Handling & character)
Thruxton 1200 (suits me)
James Captain 197 (pure adrenaline, i.e. no brakes!)
Sir J.Stewart.
Offline MarkCR750
« Reply #16 on: August 06, 2017, 04:37:54 PM »
Yes that's her G 👍
Sir J.Stewart.
Offline hairygit
« Reply #17 on: August 06, 2017, 06:10:10 PM »
Problem is, you lunatics are like trying to stop a toddler playing in a cat litter tray, you won't learn until you end up with it in your hands, and probably in your mouth too! Then whingeing about the taste!
Offline MarkCR750
« Reply #18 on: August 06, 2017, 08:49:09 PM »
Emily Ratajkowski could end up with a similar sort of problem 👍
Sir J.Stewart.
Offline MarkCR750
« Reply #19 on: September 02, 2017, 06:07:09 PM »
It's only gone and done it again !, bloody unreliable hondas 😄, starts fine from cold, runs fine at any revs, stop when it's well warmed up (10 miles this time) and it won't start, waited 10 mins and it started with a handful of throttle, then ran fine at any revs again, when I got home I meant to see if it would start hot again, but being a bit senile I forgot and put it away, any thoughts?.
Sir J.Stewart.
Offline hairygit
« Reply #20 on: September 02, 2017, 06:17:21 PM »
Just a thought here, are you using points or electronic ignition? I knew a guy with a 400/4 with electronic gave similar issues, only when hot, turned out the pick ups were being affected by the heat in the points cover, causing massively increased electrical resistance. That's why superconductors work best at the coldest they can.
Offline MarkCR750
« Reply #21 on: September 02, 2017, 06:58:04 PM »
Electronic, the original Piranha set up that came with the donor bike, it must be 20+ years old as the previous owner took it off the road in 1995, so you could be onto something there H, I believe that the Newtronic set up is pretty much the same as the old Piranha so maybe it's time to invest in a new one.
Sir J.Stewart.
Offline hairygit
« Reply #22 on: September 02, 2017, 07:02:19 PM »
If you have the stuff to try it with conventional points, give that a try before spending loads when it may not be the issue, or maybe there are shitalian components in the electronic system! (Couldn't resist that!)
« Reply #23 on: September 02, 2017, 07:22:26 PM »
Take a spare plug out with you and if it does it again you can check for a spark there and then on any of the cylinders to see if the ignition isn't working or it's something else.
My dad's friend always just put his finger in the plug caps to check for sparks years ago,  proper old mechanic's fingers he had.
Offline flatfour
« Reply #24 on: September 02, 2017, 07:50:51 PM »
The Newtronic system fitted to my Benelli 750/6 would do exactly as you describe - run perfectly for many miles (sometimes as much as 2,000 miles went by between failures) and then stop producing sparks, only for it all to work normally again a while later.
It's the only bike that I've ever owned that went home on a trailer (twice).
The problem would, when it occurred manifest itself after a short spell of idling (i.e. at traffic lights). Things would then return to normal after everything cooled down.
Offline MarkCR750
« Reply #25 on: September 02, 2017, 08:21:57 PM »
Ha, actually my 900ss has developed a minor issue, tickover a little high, you can bring it down to normal by quickly cracking the throttle open and shut, I suspect the previous owner may have fitted a Honda throttle cable 😐
Sir J.Stewart.
Offline MarkCR750
« Reply #26 on: September 02, 2017, 08:23:08 PM »
Great tip, I'll do that.
Sir J.Stewart.
Offline MarkCR750
« Reply #27 on: September 02, 2017, 08:36:03 PM »
Thanks all for the comments/advice I'll have a look at it next weekend, busy tomorrow it's Italian bike day at CMC clay cross, see you there H 👍
Sir J.Stewart.
Greebo
  • Guest
« Reply #28 on: September 03, 2017, 10:15:01 AM »
Mines got the Dave Silvers one on Mark about £99.00..& simple to fit.
PS... did you get my private message  yesterday ?
Offline MarkCR750
« Reply #29 on: September 03, 2017, 04:52:29 PM »
Just read it G, bad news followed by good news!, I thought I saw you as I rode away from CMC but I guess it was another thruxton owner.
PS thanks for the DS tip, £99 is a bargain if I end up needing one.
PPS just check on DS website, they are now £110 but that's still cheap.
« Last Edit: September 03, 2017, 04:58:53 PM by MarkCR750 »
Sir J.Stewart.
