Author Topic: CB400f Breather pipes  (Read 528 times)
Offline Integra99
« on: December 05, 2017, 04:00:02 PM »
Hi all, I'm hoping someone can shed some light on this, I cannot for the life of me remember the breather pipe set up on my 400 so apologies if this is a stupid question but mine were all perished and fell apart.
Does the cam breather route to the airbox (via the 2nd inlet on the plastic chamber)? I'm assuming it should. I can see the airbox and chamber both have vertical breathers so these must exit straight out. However following the cam breather pipe... does this use the T piece and go to the airbox only (my T piece is blocked off) or should it us the T piece and connect to the airbox and also exit out?
I hope this makes sense, its just I'm making new breather pipes and want to cut it first time correctly!
Re: CB400f Breather pipes
« Reply #1 on: December 05, 2017, 10:43:45 PM »
I will put some pics on tomorrow  ;)
Offline Integra99
« Reply #2 on: December 06, 2017, 09:18:06 AM »
That would be great.. as I cannot find anything on Google to show the way they link!
« Reply #3 on: December 06, 2017, 09:46:32 AM »
The hose showing is the one that goes to the engine breather
The bottom one in the picture is a drain and goes to air and the one on the plenum is a drain and goes to air
Offline Integra99
« Reply #4 on: December 06, 2017, 10:38:52 AM »
Many thanks, ok so that literally goes straight to the top cam breather cover! On my old pipes I have a blocked off T piece but maybe this was put in by the PO! to join two short pipes.
So in total 3 breathers, cam to airbox (plastic chamber) as in photo
And then the two drain pipes 1 for the airbox and one for the filter box.
Lovely thank you...
