Author Topic: Replacement horn  (Read 872 times)
Offline ogri211
Replacement horn
« on: March 30, 2018, 07:50:19 PM »
I need to replace the horn on my 400 I dont think I would be able to get one of the originals with the plastic cover, what would be the recommendations for a replacement.
Triumph Rocket3, Suzuki GT 750A, Kawasaki H1B, Honda 400 Four, Triumph Speed Triple
Offline hairygit
Re: Replacement horn
« Reply #1 on: March 30, 2018, 07:54:19 PM »
Have you tried fixing the original? Ashimoto  done an article about boiling them in a saucepan (not joking) and other things you can do to get them working again.
Offline ogri211
« Reply #2 on: March 30, 2018, 08:02:33 PM »
unfortunately I dont have the original I was going to try and get a second hand one and either fix it or fit the plastic cover to a similar one if I can find one.
Offline hairygit
« Reply #3 on: March 30, 2018, 08:12:50 PM »
Okay, when you said you needed to replace it I assumed your original had stopped working.
« Reply #4 on: March 30, 2018, 08:46:17 PM »
Got me wrong there   :) ...that's someone else's  fix that I don't advocate.
http://www.sohc.co.uk/index.php/topic,13195.0.html
I do have another theory though, not tried yet .. feed the horn with high frequency, high voltage with voltage high enough to jump the high resistance film on the points. The discharge arc may electrically 'clean' the contacts and if left arcing for long enough may destroy the resistive corrosion layer. ... I do  have a horn somewhere...will have to try it out sometime.
« Last Edit: March 30, 2018, 08:51:46 PM by AshimotoK0 »
« Reply #5 on: March 30, 2018, 10:32:41 PM »
Ash, no need to ruin one of your own horns during the trial, feel free to use my non working horn from my own 400  ;)
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #6 on: March 30, 2018, 10:39:55 PM »
If you want to send me it I will have a go...If it doesn't work I will use the other  'invasive'  method.
« Reply #7 on: March 30, 2018, 11:02:48 PM »
Wow, that's an offer I can't refuse, thanks Ash :).
I'll dig it out over the rainy easter weekend and let you know when I find it.
1976 Honda 400/4
Offline kevski
« Reply #8 on: March 31, 2018, 05:13:11 PM »
I picked up a pair of the chrome covered horns like on my 350 dirt cheap six screws cleaned the points and they work lovely, a pair of two tones now for my Zed.
« Reply #9 on: March 31, 2018, 05:30:23 PM »
The 400/4 horn is different though .. the 350/4 is  probably like the CB350 twin & CB750K0-etc and can be easily dismantled to get to the points. On the 400/4, CB250/360 G5, etc  it's crimped together and to gain full access to the points you have to de-crimp as detailed in my write-up. Or use one of the other fixes.
Offline ogri211
« Reply #10 on: March 31, 2018, 09:14:27 PM »
Ive found one on Ebay its a Mitsuba MB-E it is used on lots of old Hondas I just need to find a cover to finish it off.
« Reply #11 on: March 31, 2018, 09:17:37 PM »
If only we could turn the clock back a couple of weeks....i wouldn't have put mine on fleabay if I had known you needed one, sorry.
Offline ogri211
« Reply #12 on: March 31, 2018, 10:06:38 PM »
No problem I dont think it will stop me from putting the bike on the road, I got a horn from another Honda which is identical apart from the cover so Im sure one will come along.
« Last Edit: April 01, 2018, 01:49:52 PM by AshimotoK0 »
Offline ogri211
« Reply #14 on: April 01, 2018, 06:47:01 PM »
Thanks for that, I managed to get one from another Honda it looks to be the exact horn without the plastic cover, a lot of the Hondas from the 80s and 90s use the Mitsuba MB-E so I got a good one for a tenner of ebay.
