Author Topic: Clutch switch diode  (Read 1984 times)
Offline alexojones
Clutch switch diode
« on: April 18, 2018, 07:20:57 AM »
Hello
Does anyone know where I can get a clutch switch diode from , I live in the UK and I’ve got a 1978 CB750K .
I’ve got a green and red wire in the headlight which I think need a diode .I’ve managed to find a new clutch switch on eBay but looking at the diagram and reading the forums  I think I need a diode to connect the two .
Please let me know if I’m wrong as I’m very new to this !
Thanks in advance
Alex
Re: Clutch switch diode
« Reply #1 on: April 18, 2018, 07:48:19 AM »
I think the diode is located under your left side panel on a 78. It will be at the bottom and the wires should be light green with red and dark green with red.
Offline alexojones
« Reply #2 on: April 18, 2018, 07:57:12 AM »
Thanks Trigger, in that case I’ve got the Diode, do I just connect the green and red wire in the headlight direct to the clutch switch then ?
Alex
« Reply #3 on: April 18, 2018, 08:01:04 AM »
Alex
Yep, the switch connects in the head light. Don't know how the hell you test these diodes to see if they work or not.
From memory, the switch should have two wires
Sent from my cheap phone with a shite camera
« Last Edit: April 18, 2018, 08:05:16 AM by Trigger »
Offline alexojones
« Reply #4 on: April 18, 2018, 08:14:57 AM »
Nice one thanks Trigger
« Reply #5 on: April 18, 2018, 08:16:53 AM »
If it’s like any other diode with a multi meter you will get a reading one way and open circuit the other.
Open circuit both ways bin, short circuit both ways bin ;D
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
« Reply #6 on: April 18, 2018, 08:20:18 AM »
Just dug a original switch out, two wires. Green and a Green with red.
Sent from my cheap phone with shite camera, using my finger
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #7 on: April 18, 2018, 10:40:02 AM »
Also check the clutch switch (as image) with a continuity tester, they can stick over time.
Alan
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline mike the bike
« Reply #8 on: April 18, 2018, 12:03:37 PM »
Before wasting money on a diode, check with a meter.  If no meter check with the battery and a bulb.  A working diode will only conduct in one direction.
Offline philward
« Reply #9 on: April 18, 2018, 10:16:16 PM »
Sorry to high jack the thread! On my CR rep I'm nearly finished, I've used a new K6 loom as a basis for the CR's loom (as all the electrical bits have been re-located to the seat hump area). The CR will have all fully functioning lights (idiot lights in digital speedo) etc. and has new K2 switch gear which doesn't have the clutch switch or the 'starter motor safety switch' (on reflection shouldmhave bought K2 loom).
Question - do I just connnect the wires from nuetral and clutch input wires that woulld ordinarily go to the 'starter motor switch' (term used on online wiring diagram - diode?)
« Reply #10 on: April 19, 2018, 07:35:07 AM »
In theory if you just connect the two loom wires in the headlamp shell that should go to the switch together all should work as the system is an EITHER neutral light on OR lever pulled to start
Offline alexojones
« Reply #11 on: April 19, 2018, 01:00:05 PM »
This is probably a dumb question , so apologies in advance, I’m trying to replace the clutch switch. On my clutch lever there is a bit of plastic sticking out where I’m guessing the old one broke off , how do I get this out . I can see a small hole on bottom of clutch lever as per photo I’ve tried this but no luck .Do I just use more force and pull old bit of plastic out ?
Alex
Offline hairygit
« Reply #12 on: April 19, 2018, 01:29:55 PM »
You have to take the clutch lever off the bike, then it just pushes out. Fit the new one from the lever side by threading the wires through then pulling gently until the switch positions itself in the recess.
Offline alexojones
« Reply #13 on: April 19, 2018, 02:52:44 PM »
Thanks for the advise , all fitted now. Seemed bloody obvious once you’d told me !
Offline philward
« Reply #14 on: April 19, 2018, 07:13:33 PM »
Thanks Brian - just to confirm - I havn't got a clutch switch or the diode. So the 2 way connector that goes to the 'starter motor switch' (term used on online wiring diagram – is this the diode?), just leave un-connected?
